_______
COLUMNS
The Savvy Aviator #14: Engine Cooling — Less Is More
If your CHTs are running warmer than you’d like, odds are that you’ve got leaky cooling baffles under your cowling. Fixing those leaks is usually simple — and the less air leaks, the more is available to cool the cylinders.
New Articles and Features on AVweb
- High Cylinder Head Temperatures (CHTs) are frequently a symptom of leaky cooling baffles in an aircraft engine.
- Fixing these baffle leaks is typically a simple process.
- Minimizing air leakage through baffles ensures more air is efficiently directed to cool the cylinders, thereby improving overall engine cooling.
