April 12 | April 19 | April26 | May 3 | May 10 | May17
| Monday, April 12, 1999 |
Crankshaft Problems Plague Teledyne Continental Motors
New TCM Crankshafts Breaking In 520/550 Engines…
At least six new and factory-rebuilt Teledyne Continental Motors (TCM) 520- and550-series engines produced by TCM during a three-month period have suffered brokencrankshafts. This alarming fact came to light last week when TCM’s new Director of FieldSales and Service, Bill Blackwood, phoned 127 owners of new and remanufactured engineswith crankshafts manufactured between March 11 and June 18, 1998, and asked them to havetheir crankshafts inspected at TCM’s expense. TCM is asking each owner to have the #1 and#3 cylinders and connecting rods removed so that a dye-penetrant inspection of thecrankshaft can be performed on the aft side of the #2 crankshaft cheek, where five of thesix breaks have occurred. Additionally, TCM has issued Special Service Instruction SSI99-1, which details the inspection procedure and the area to be inspected.
…Few Clues So Far As To Cause Or Scope…
So far, there are few clues to the cause of these breakages nor any obvious pattern toindicate which engines may be at risk. The six or seven known failures (the exact numberdepends on whom you talk to) appear to have occurred in both two- and three-bladed propinstallations, both Hartzell and McCauley props, both sandcast (rear alternator) andpermold (front alternator) engine configurations and on both new and rebuilt engines. Allwere the latest-style vacuum-arc remelt (VAR) crankshafts. Affected aircraft include aMooney Ovation, a Piper Malibu, a Cessna T210, a Beech Baron, a Cessna 206/207, plus anIO-550 on an unidentified aircraft. Luckily, only one of the aircraft was damaged andthere has been only one minor injury resulting from this problem to date. So far, the onlyreal clue seems to be that the broken crankshafts were all manufactured between March 11and June 18, 1998. Five of the six cranks broke on the aft side of the #2 cheek, and thebreaks were almost identical in location and shape. The March 11 failure occurred on the#5 cheek, and it is not yet known whether it is related to the other five (or six). Thebreaks occurred at between 85 and 175 hours time-in-service.
…TCM Asking Owners For Help…
TCM is currently asking for inspection of other crankshafts manufactured on the same,previous or following day as each of the six failed cranks. Furthermore, they arepresently concentrating on cranks with between 50 and 200 hours time-in-service. Dependingon the results of these field inspections, TCM may well call for inspection of a widerrange of crankshafts in the coming weeks. After arrangements are made to remove thecylinders and connecting rods, owners are asked to contact Blackwood on a special tollfree phone number (888-200-7565) for coordination with a factory tech rep for inspection.TCM is paying for all parts and labor costs.
How can an owner tell if his crankshaft should be inspected? Each new crankshaft has aserial number consisting of seven or eight characters stamped or vibro-etched on the edgeof the prop-mounting flange. The first character is a letter that denotes the month ofmanufacture (A for January, B for February, etc.). The next two digits denote the day ofthe month and the two digits after them denote the year. The last two digits are asequence number for crankshafts manufactured that day and an “N” suffix is usedto denote a nitrided crankshaft.
According to TCM, the manufacture dates of the known failures were March 11, May 11,May 12, May 13, June 10, June 17, and June 18, 1998. Since TCM wants to inspect allcrankshafts manufactured on these dates plus one day earlier and one day later, thecomplete list of date codes to be inspected is: C1098xxx, C1198xxx, C1298xxx, E1098xxx,E1198xxx, E1298xxx, E1398xxx, E1498xxx, F0998xxx, F1098xxx, F1198xxx, F1698xxx, F1798xxx,F1898xxx, F1998xxx.
…What Owners Should Do Now
Owners of factory new or rebuilt TCM 520 or 550 engines manufactured since March 1998and those who have field overhauled engines with new crankshafts of the same vintageshould immediately check the crankshaft date code on the prop mounting flange to determinethe manufacture date. If your crankshaft was manufactured between March and June of 1998,contact TCM’s Bill Blackwood at 888-200-7565 for instructions. If your crank manufacturedate falls outside that range, hang onto the date code in case TCM expands the scope ofthe inspections.
| Monday, April 19, 1999 |
Teledyne Continental Will Order Massive Crankshaft Inspection
Affects All TCM 470-, 520- And 550-Series Cranks Built In 1998…
Teledyne Continental Motors (TCM) executives and engineers worked feverishly last weekand through the weekend on a new mandatory Service Bulletin that will require some 2,200nearly-new big-bore TCM engines to be opened up for ultrasonic inspection of theircrankshafts. According to TCM’s John Barton, Senior Director of Engineering, the order —to be known as Critical Service Bulletin 99-3 — will affect all new and factory-rebuilt470-, 520- and 550-series engines with crankshafts manufactured between January 1 andDecember 31, 1998, as well as field-overhauled engines with the crankshafts installed. TCMsays it expects to release CSB 99-3 this week, and a Priority Letter AirworthinessDirective ordering compliance is expected from the FAA next week. Owners of engines withthe affected crankshafts will be required to have the #1 and #3 cylinders, pistons andconnecting rods removed from the engine to expose the crankshaft. Both harmonic dampenercounterweights will also have to be removed. An ultrasonic inspection of the #2 and #5crankshaft cheeks must then be performed by designated TCM personnel. TCM says it will payfor the disassembly, inspection, and reassembly of the engines.
…A Classic Whodunnit…
It was late last year when TCM first became aware of crankshaft failures in seven ofits 520- and 550-series engines of a type never seen before. Metallurgical analysisrevealed these to be fatigue fractures in the #2 or #5 “long cheeks” near wherethe harmonic dampener counterweights are attached. What made these failures particularlysurprising to TCM engineers was that the area of failure is a low-stress area of thecrankshaft. Engineering calculations indicated that the area in question should have beensubject to a maximum stress of only 23,000 PSI and that the crankshaft should have beenable to withstand 120,000 PSI before failing. In fact, it appeared that the sevencrankshafts that failed in this manner all had fractures that progressed nearly 90% of theway through the cheek before the crankshafts ultimately failed. TCM had seen crankshaftfailures before but never in low-stress areas like this.
What could be causing this? TCM engineers were baffled. The only clue they had was anodd pattern in the manufacture dates of the seven broken crankshafts. The earliest one wasmanufactured in March 1998. Then there were three failures in cranks manufactured within aone-week period of May and three more in cranks manufactured during a one-week period inJune. All seven crankshafts had very low time when they failed: between 85 and 175 hoursin service. Six of the seven failed in the exact same spot on the #2 cheek, while theseventh failed in the corresponding location on the #5 cheek.
As AVweb reported last week, TCM responded by contacting 127 owners of new andfactory-rebuilt engines with crankshafts manufactured within one day of the dates of theseven failed cranks. The owners were asked to remove the #1 and #2 cylinders so that a dyepenetrant inspection of the #2 and #5 cheeks could be performed. TCM issued SpecialService Instruction SSI 99-1 to describe the inspection procedure. Priority was given toengines that had between 50 and 200 hours. In all, some 54 crankshafts were inspectedunder SSI 99-1. Only one — in an IO-520 engine on a Beech Baron — showed any anomalies.Inspection of that Baron’s engine revealed a tiny crack in the #2 check area preciselywhere most of the broken crankshafts had failed. This turned out to be the break that theTCM engineers needed to solve the puzzle.
The Baron engine was torn down and the crank analyzed in TCM’s metallurgy lab. Althoughthe crack seemed almost insignificant, it had breached the outer nitride “case”of the crankshaft (which is only .025” thick). The nitrided surface of these cranksis extremely hard and not easy to damage inadvertently. After eliminating various otherpossibilities, TCM engineering sleuths concluded that the damage must have been caused bya 5-ton hydraulic ram used to press counterweight bushings into the crankshafts during thefinal stages of manufacture. Factory records indicated that there had been some problemswith the tooling used to do this and that the tooling had been repaired at one pointduring 1998 and finally replaced altogether in December. Apparently, concluded TCM, thetroublesome tool had managed to nick the cheeks of some crankshafts during the bushinginsertion process and it was those nicks that subsequently caused seven crankshafts tofracture.
…Assessing The Magnitude…
The seven crankshafts all failed in flight, six of them in single-engine airplanes.Fortunately, six of those aircraft were able to make on-airport landings, while theseventh landed off-airport but caused only minor injuries to the occupants. That’s thegood news. The bad news is that TCM has no way of knowing how many other crankshafts weredamaged by the errant hydraulic ram. Based on the results of the SSI 99-1 inspection, it’slikely that relatively few crankshafts were affected. In fact, it’s entirely possible thatall of the crankshafts that are ever going to fail from this problem have already failed.But with lives potentially at stake, neither TCM nor the FAA was willing to bet on it.
After intense discussions between TCM top management and the FAA’s Atlanta MIDO whichoversees TCM’s Mobile, Ala., manufacturing operations, it was decided that everycrankshaft that could conceivably have been damaged would have to be inspected. Althoughthe seven cranks that failed were all from 520- and 550-series engines, the decision wasmade to include 470-series engines in the inspection program — including the O-470engines that power the ubiquitous Cessna 182 — since those crankshafts were built usingthe suspect tooling. Furthermore, although all the failed cranks were manufactured in thesecond quarter of 1998, TCM decided to extend the scope of the inspection program to all2,200 crankshafts manufactured during the entire year.
Although the preliminary fact-finding inspection of SSI 99-1 involved a simple dyepenetrant inspection, TCM concluded that a more sensitive inspection method was needed tomake certain that even the tiniest cheek fracture would be detected. The traditionalmethod used to inspect crankshafts is magnetic particle inspection(“Magnaflux”), but it requires that the crankshaft be removed from the engine.TCM finally came up with an ultrasonic inspection technique that offers the desiredsensitivity yet can be done without splitting the engine case. The downside of theultrasonic inspection is that it’s not the sort of thing that your friendly neighborhoodA&P can do — it requires special and costly equipment and must be performed by ahighly trained technician.
…What Happens Next?
Within the next few days, TCM plans to issue Critical Service Bulletin 99-3 that willidentify all affected new and factory-rebuilt engines by serial number. It will alsoprovide instructions for determining the crankshaft manufacture date from the date codestamped on the propeller-mounting flange for field-overhauled engines and for crankshaftsin the inventories of distributors and overhaul shops. Under CSB 99-3, owners of affectedengines will be required to have their engines prepared for inspection at a maintenancefacility of their choice by removing the #1 and #3 cylinders, pistons, connecting rods andcounterweights. Then, an ultrasonic inspection must be performed by a TCM-designatedinspector. TCM will pay for the engine disassembly and reassembly and will provide theinspections without charge. According to Barton, TCM and the FAA will require that theinspection be done within the next 10 hours for engines with affected cranks that have 300hours or less time in service. Engines that have accumulated more than 300 hours willprobably have an extended compliance time, on the theory that if their cranks were goingto fail, they would have done so by now.
The logistics of this inspection program are daunting. TCM’s John Barton tells AVwebthat the United States will be divided into eight regions, with one designated inspectorassigned to each region, plus two “roaming” inspectors to handle specialsituations such as fleet operators. Plans for international logistics were still beingformulated at deadline. The designated inspectors will be a combination of TCM employeesand contractors from Law Engineering, an internationally-known firm specializing innon-destructive testing. The inspectors were undergoing training in Mobile last week andshould be deployed to the field sometime this week. TCM has also established a specialtelephone center to facilitate the scheduling of these inspections. Owners, operators ormaintenance facilities will be asked to call TCM toll-free at 1-888-200-7565 to provideinformation about their engines and to schedule a specific date and place for theultrasonic inspection. TCM says it will also provide specific instructions and a copy ofCSB 99-3 on the TCM-link web site.
One question remains unanswered: Is it possible for a relative handful ofTCM-designated inspectors to inspect some 2,200 crankshafts within the constraints of a10-hour compliance window without grounding a lot of airplanes for a painful amount oftime? As we said earlier, the logistics are daunting.
NOTE: AVweb’s coverage includes TCM’s SSI 99-1. AVweb will also include CSB 99-3 as soon as it is available.
Monday, April 26, 1999
TCM Crank Issues Get Curiouser And Curiouser
Latest On TCM Crankshaft Inspections…
Early last week, Teledyne Continental Motors issued Critical Service Bulletin (CSB)99-3 mandating ultrasonic inspection of all TCM 470-, 520- and 550-series crankshaftsmanufactured during 1998. The bulletin was basically as we described it to you last week,with a few new wrinkles. The biggest surprise was that the number of affected crankshaftshas increased from 2,200 to more than 3,000 — mostly because TCM realized at the lastmoment that reconditioned crankshafts used in its rebuilt engines had to be included inthe inspection program. Those cranks made the cut since they received new counterweightbushings installed by the same five-ton hydraulic ram that was implicated in the failureof seven new crankshafts. TCM set the compliance time at 10 hours for crankshafts with upto 300 hours time-in-service, and 25 hours for those with over 300 hours. At week’s end,the FAA had issued Priority Letter Airworthiness Directive 99-09-17 to give the force oflaw to CSB 99-3.
…Will Be Costly For TCM, Painful For Owners
As AVweb reported last week, affected TCM engines will have to be prepped forinspection by having the #1 and #3 cylinders, pistons, connecting rods and counterweightsremoved from the engine to expose the crankshaft. A TCM-designated technician will thenperform the ultrasonic crankshaft inspection, after which the engine must be reassembled.TCM will reimburse up to $700 for the disassembly and reassembly of normally aspiratedengines — and up to $900 for turbocharged engines — and will provide the ultrasonicinspection itself at no charge. The big remaining unknown for owners is how long theirairplanes will be out of commission awaiting inspection. Given that TCM presently has onlyten designated inspectors to cover the entire United States, some quick arithmetic wouldsuggest that it could take as much as six months to inspect the more than 3,000 affectedengines. However, TCM’s John Barton told AVweb that the company was working on aplan to recruit and train additional inspectors and to obtain more ultrasonic testingequipment for them to use. We’ll keep you posted. Meantime, your best bet is probably totake your plane to a large metropolitan maintenance facility where lots of other airplanesare being similarly prepped for inspection, since it’s a fair guess that those shops willhave first priority on the TCM inspectors’ itineraries. And be sure to complete the CSB99-3 contact form online ASAP so you get on the inspection schedule ahead of thoseunenviable souls who don’t read AVweb news.
NOTE: AVweb’s coverage includes the full text of TCM CSB 99-3, in both HTML and PDF formats, plus a synopsis, FAQ, and a link to the CSB 99-3 online contact form.
Monday, May 3, 1999
TCM Crankshaft Update
Continental Moves To Expedite Inspections…
After a week of confusion, mixed signals and unreturned phone calls that had manyaffected owners hopping mad, Teledyne Continental Motors appears to be getting its acttogether with respect to the crankshaft inspections mandated by TCM Critical ServiceBulletin 99-3 and FAA Airworthiness Directive 99-09-17. On Saturday, TCM told AVwebthat it had doubled the number of trained ultrasonic inspection technicians assigned tothe program — from 10 to 20 — with even more inspectors currently in training. Thecompany also said that it was about to release regional inspection schedules advising wheninspectors would be working for the next two weeks at designated FBOs around the country,enabling owners to expedite the inspection process by bringing their aircraft to theinspectors rather than waiting for the inspectors to come to them. The schedules will beupdated weekly, with inspectors continuing to make the rounds of FBOs as necessary afterthe initial pass. In addition, TCM announced that it will conduct the CSB 99-3 inspectionson a full-time basis at its facility in Fairhope, Ala. (4R4), and that it was consideringother locations at which inspections would be conducted full-time.
…And Minimize Owner Pain
TCM also indicated that owners of factory new and rebuilt engines will receive aspecial warranty covering 100% of parts and labor for six months or 240 hours uponcompletion of CSB 99-3 requirements. For engines already covered by TCM warranty, thenormal coverage will be superseded by the special warranty and resume after six months.TCM plans to mail details of the special warranty and inspection schedules to all ownerswho have contacted TCM to arrange CSB 99-3 inspections, as well as posting them atwww.tcmlink.com/recent.htm. At press time,less than half of the 3,000 affected 470-, 520- and 550-series engines with crankshaftsbuilt in 1998 had been registered in TCM’s contact database. Owners who have not yet doneso are urged to call TCM toll-free at 1-888-200-7565 or to complete the online contactform at www.tcmlink.com/form.html.
Monday, May 10, 1999
TCM Getting Aggressive On Crankshaft Problems
More Inspectors Added To Tackle Large Workload…
As Teledyne Continental Motors continued to climb a steep learning curve associatedwith its field program to inspect 3,200 crankshafts, the company announced last week thatthey were hiring and training 20 additional inspectors to expedite the inspections. Asmany as 40 inspectors should be available to inspect the suspect crankshafts by late May,and TCM is now saying that the required inspection —which involves four specific areas of the crankshaft and is averaging 30 to 45 minutes perengine — can be accomplished more efficiently than originally thought. As reported by AVwebover the last several weeks, TCM discovered that faulty crankshafts could have beeninstalled in new, factory-remanufactured, or field-overhauled 470-, 520- and 550-seriesengines produced in 1998. TCM has designated a number of service centers at FBOs acrossthe country and has set a schedule for when inspectors will be at those sites. TCM isleasing aircraft to fly inspection teams to those sites for the scheduled ultrasonicinspections. Owners of affected aircraft can check the TCMweb site or call TCM at 888-200-7565 to register and find the nearest designatedinspection station.
…Of Urgent Engine Inspections…
According to the AD and TCM Critical Service BulletinCSB99-3A, affected engines with 300 hours or less time-in-service can fly ten hoursafter operator receipt of the Priority Letter AD; planes with more than 300 hours TIS canfly 50 hours after receipt. The Cessna Pilots Association is recommending to its membersthat they may want to arrange to bring their own mechanic with tools to remove and replacethe cylinders for the inspection, since some shops report that they can’t accommodate allthe pre-and post-inspection engine work with their own mechanics. With TCM allowing $700to $900 for the pre- and post- inspection engine work, bringing a mechanic to the sitecould be the quickest way to complete the inspection. Still unknown is how crankshaftinspections will be handled for foreign owners of affected engines. TCM is only sayingthat inspections in foreign countries are presently in the planning stage and won’t giveany inspection dates. To help alleviate some of the aggravation suffered by owners, TCMalso said they will issue a six-month/240-hours 100 percent Parts and Labor warranty toowners that are affected by this AD as appreciation for supporting the inspection process.
…But Inspections May Not Be Going Smoothly
TCM says that one inspector can check 10 or 12 engines per day under optimalcircumstances. But the inspections aren’t all going quite that smoothly: One AVwebreader reports that an inspector showed up at one Alaskan FBO two days behind schedule,inspected only 10 of the 17 prepared engines, then departed for his next scheduledlocation, leaving seven engines in limbo and owners climbing the walls. AVweb hasasked TCM to comment on the reader’s report. Meanwhile, TCM reports that the inspectionsto date have turned up no fatigue fractures but a significant number of potentialproblems, resulting in several dozen engines being returned to TCM headquarters in Mobile,Ala., for installation of new crankshafts and post-mortem metallurgical analysis of the”old” ones. TCM is promising to turn around these engines in approximately twoweeks, which will undoubtedly have some impact on the availability of new andremanufactured engines for other customers — especially if the ultrasonic testing”failure rate” continues at the current level. Stay tuned to AVweb forreports on the latest developments in this evolving situation.
Monday, May 17, 1999
TCM Crankshaft Inspection Update
One Step Forward, One Step Back?
As Teledyne Continental Motors’ efforts to inspect some 3,200 of its 470-, 520- and550-series engines continued last week, a clearer picture emerged of the scope of the taskfacing TCM and how well the company was holding up. The answer? TCM is making an admirableeffort to deal with the task it faces, but it sure looks like it’s going to be a long, hotsummer at company headquarters in Mobile, Ala.
Last week, AVweb reported on an abortive visit by a TCM inspector to an FBO inPalmer, Alaska, at which 17 engines were to be inspected. We told you that after lookingat 10 of the 17, the inspector left, saying that he was late for his next appointment,leaving seven engines in limbo and their owners hopping mad. After our story, TCM phoned AVwebto express displeasure with the story, explaining that according to TCM tech rep LorenLemen, the seven engines were not inspected because they had not been fully prepped forthe inspection, leaving the TCM inspector little choice but to move on.
That’s reasonable enough, but what about last Friday at Santa Maria, Calif. (SMX)?Located somewhat off the beaten path on the central California coast, SMX nonethelessserves as headquarters for the Cessna Pilots Association (CPA) and, coincidentally, ishome base for AVweb Editor-in-Chief Mike Busch’s Cessna T310. Well, Mike and CPAExecutive Director John Frank showed up at Aero-West Specialties, the largest aircraftservice facility at SMX, to see how the inspections were progressing, but the TCMinspector never showed. To make matters worse, nobody from TCM bothered to call the FBO totell them that the inspector wouldn’t be coming, leaving Aero-West owner Michael Lentini ,several of his mechanics, three aircraft owners, Mike Busch and John Frank all twistingslowly in the wind. After numerous phone calls to Mobile, FBO owner Lentini was told thatthe designated TCM inspection team had encountered a lot more engines prepped forinspection at their preceding scheduled location than they’d been told to expect, and uponreporting this to Mobile, they were instructed to stay and finish them. Ultimately, a”Plan B” was negotiated, which called for the inspectors to show up at SMX onSunday. The inspections of three engines took place Sunday morning — two of the threeengines failed, incidentally — and AVweb‘s Mike Busch was there, camera andnotepad in hand.
Despite the two-out-of-three failure rate at SMX, however, it appears that only about10 percent of the engines inspected so far under CSB 99-3 have failed the ultrasonictesting procedure and are being shipped to Mobile for crankshaft replacement. Weunderstand that nearly 100 engines have been earmarked for crank transplant so far, andthat the TCM factory is running seven days a week, two shifts a day, to turn them aroundas quickly as possible. So far, the turnaround on engines returned to Mobile appears to beabout three weeks, but there’s no telling whether TCM can hold the line on that as theinspection program proceeds.
Needless to say, AVweb will continue to monitor and report on TCM’s response tothis daunting challenge. Meantime, look for Mike Busch’sin-depth first-person report about the TCM crankshaft inspection process next week.
