Australias Transport Safety Bureau (ATSB) announced last week that it will reopen the investigation into the May 2000 crash of a Whyalla Airlines Piper Chieftain, a development which could tie directly to Lycomings massive recall of potentially defective crankshafts. The Whyalla Chieftain plunged into Spencer Gulf north of Adelaide after a dual engine failure, killing all seven passengers and the pilot. The ATSBs report on the crash of VH-MZK, released in December of 2001, concluded that the Chieftains two Lycoming TSIO-JT2B engines failed dependently, meaning that the failure of the left engine caused the pilot to select a higher power setting on the right engine, which subsequently failed. The ATSBs investigation blamed the use of anti-galling compound between the rod bearing and end cap for the failure of the left engine, whose crankshaft broke. Further, it claimed that Whyallas engine-leaning practices contributed to the failure of bothengines. The ATSBs theory, which has been roundly criticized in the U.S., is that Whyallas leaning methods caused a build-up of lead oxybromide deposits on pistons. These deposits, according to the ATSB, caused pre-ignition and the failure of the right engine at high power. The ATSB came under fire this fall when South Australian Coroner Wayne Chivell opened his own investigation into the crash, which brought him to the U.S. to depose General Aviation Modifications Inc. chief engineer George Braly. The Whyalla engines are in the U.S. and the ATSB has asked the U.S. NTSB to assist in further analysis of the wreckage, especially the crankshaft in the left engine. According to the ATSB, one reason the probe was reopened is that the Chieftains left crankshaft serial number was among those recalled by Lycoming in September because of improper manufacturing procedures. Not surprisingly, a number of lawsuits arepending as a result of the Whyalla crash.
NOTE: For more on the Whyalla crash, see the ATSB’s media release and, on AVweb, John Deakins detailed analysis of the ATSB report.
Australia Whyalla Crash Probe Reopened
- Australia's ATSB has reopened its investigation into the 2000 Whyalla Airlines crash, which killed eight, due to a potential link between the left engine's crankshaft failure and a massive Lycoming recall for improperly manufactured crankshafts.
- The original 2001 ATSB report blamed the left engine failure on an anti-galling compound and the right engine failure on the airline's engine-leaning practices causing pre-ignition, conclusions that were widely criticized in the U.S.
- The reopened probe, partly prompted by an independent investigation from a South Australian Coroner, involves U.S. NTSB assistance for further analysis of the wreckage, especially the left engine's crankshaft.
