Passenger Killed In Taxi Accident
  • A fatal taxiing accident occurred at AirVenture when a Grumman TBM Avenger ran into an RV-6 homebuilt from behind.
  • Gary Palmer, a 63-year-old passenger in the RV-6 and president of EAA Chapter 245, was killed in the incident at Oshkosh airport.
  • The accident happened on a taxiway as both aircraft were in line for departure, with the Avenger's limited forward visibility noted.
  • The RV pilot and the two occupants of the Avenger were unhurt, and the NTSB is continuing its investigation into the accident.
Shortly after noon as this year’s AirVenture was nearing its close, a passenger in an RV-6 homebuilt was killed when a Grumman TBM Avenger ran into it from behind while taxiing at the Oshkosh airport. Both the Avenger (a very large WWII taildragger with limited forward visibility) and the RV were in line for departure at Wittman Field, on the taxiway on the west side of the airport’s main runway, 18-36. The propeller of the Avenger sliced into the RV and passenger Gary Palmer, 63, of Nepean, Ontario, was killed. Palmer was president of EAA Chapter 245 in Ottawa. The pilot of the RV, Donald Reed, 58, of Carp, Ontario, was unhurt, as were the two on board the Avenger. “It’s always a very difficult situation when there is a loss of life,” EAA President Tom Poberezny said in a statement on Tuesday. “Our sincere sympathy goes to the families and to all involved.” The NTSB is continuing its investigation into the accident.
