Biz AVs AD Watch
Bombardier Model CL-600-2C10
The FAA has a final rule that supersedes an existing Airworthiness Directive (AD), applicable to certain Bombardier Model CL-600-2C10 series airplanes, that currently requires a revision to the Airplane Flight Manual (AFM) to prohibit operations into known or forecast icing under certain conditions. That AD also requires an inspection to detect damage of the wing anti-ice (WAI) ducts to determine if the external shrouds of the ducts are open or cracked, and replacement of any damaged duct with a new duct or a duct with the same part number, and an optional terminating action. This amendment, which becomes effective Dec. 31, 2003, requires accomplishment of the previously optional terminating action for the AFM revision and inspection. The FAA claims actions specified by this AD are intended to prevent the WAI ducts from collapsing, cracking, or rupturing, which could cause leakage of hot air in the under-floor pressurized area of the fuselage when the anti-ice system is turned on. Such leakage of hot air results in insufficient heat for the anti-ice system and consequent aerodynamic degradation.
