Autothrottle Coming Soon For Pilatus PC-12
  • Innovation Solutions and Support (IS&S) is nearing certification for what would be the first autothrottle system in a turboprop aircraft, specifically for the single-engine PC-12.
  • The FAA has granted a Supplemental Type Certificate for IS&S's integrated PC-12 flight deck, which is compatible with the autothrottle, and is developing special certification conditions as this is a new concept for Part 23 airplanes.
  • The proposed autothrottle system will offer advanced features such as turbulence penetration auto speed, airspeed hold, under- and over-speed envelope protection, and automatic torque and engine temperature controls.
After first demoing the concept in 2015, Innovation Solutions and Support (IS&S) announced they’re one step closer to bringing an autothrottle to the single-engine turbine PC-12. IS&S says the FAA has granted the Supplemental Type Certificate for their integrated PC-12 flight deck and that new avionics package includes compatibility with the IS&S autothrottle system. The FAA says, if approved, the IS&S PT6 autothrottle will be the first certified autothrottle system in a turboprop airplane. The FAA released proposed special certification conditions for the autothrottle in a regulatory filing Friday, since there is no existing basis for certifying an autothrottle in a Part 23 airplane.
IS&S says the autothrottle will provide pilots with turbulence penetration auto speed, airspeed hold, under- and over-speed envelope protection, automatic torque control and engine temperature protections. In addition to compatibility with the autothrottle upgrade and other flight deck basics like electronic flight bag and synthetic vision, the retrofit avionics package will give operators access to RNP 0.3 approaches to get into some of the most world’s most challenging airports. Although not a household name for most pilots, IS&S has been making high-end avionics since the late 1980s when it was selected to provide its digital fuel quantity indicators for the A-10, DC-10, DC-9 and KC-10. IS&S makes retrofit avionics for the Lockheed-Martin C-130, Boeing 757/767 and McDonnell Douglas MD-90, among others.
