Savvy Analysis: Valve Protection; Report Cards
  • Savvy Analysis utilizes a massive database of engine monitor data, collected from over 1,500,000 flights, to provide advanced maintenance insights for owner-flown piston aircraft.
  • The service offers both a free platform for users to analyze their engine data and a "Pro" subscription for expert analysis, detailed reports, and automated alerts for critical engine conditions.
  • Key advanced features include Failing Exhaust Valve Analytics (FEVA), which uses proprietary algorithms to detect impending exhaust valve failures, and "Report Cards" that benchmark an aircraft's operational parameters against a cohort of similar aircraft to identify potential issues and optimize performance.
In the years since Savvy Aircraft Maintenance Management (SAMM) (see the January 2009 issue of our sister publication Aviation Consumer) brought managed aircraft maintenance from the turbine to the owner-flown piston world, the company’s practice of analyzing the engine monitor data of its clients has resulted in the collection of a massive database. According to company founder Mike Busch, it has the engine data from more than 1,500,000 flights. That massive amount of data has allowed SAVVY to provide ever-improving service to its clients by comparing their operating experience to that of similar aircraft, most recently in the formof “report cards,” warnings of potential exhaust valve failure and alerts sent to owners immediately upon receipt and analysis of engine data that shows a potentially hazardous condition.
Although engine monitors were originally developed to help pilots lean their engines in flight, the parameters they collect include extensive information on the operational health of the engines. SAMM has been using the data to diagnose problems in its customers’ airplanes—to catch developing issues before they become expensive.
Background
SAMM began looking for a computer tool to do engine monitor data analysis more efficiently. Chris Wrather, who had been involved with SAMM from its early days and holds a Ph.D. in operations research, took the lead and developed analysis tools that work in fractions of a second.
Initially, the analysis tools were only used in-house, however, as they proved effective, the decision was made to make them public and free. Thus, Savvy Analysis was born to further the mission of SAMM—to help aircraft owners do a better job of operating and maintaining their aircraft—as well as to add to SAMM’s database for its ongoing research. SAMM and Savvy Analysis do not share the data they receive with anyone; however, the person who uploads data may share it with others.
Free Service
Users can upload data from any type engine monitor. The Savvy Analysis software opens and displays it in graphic format, sorted by flight. The user can then sort his or her flights as desired and take advantage of the analysis tools on the site. There is what we consider to be a user-friendly operating guide that helps the user get into and understand the graphically displayed data. Moving the cursor along the data provides a digital readout of each parameter—including temps, fuel flow and time—in what is referred to as a dynamic data box.
The software allows the user to look at the behavior of just the odd- or even-number cylinders to see if the mags are timed the same and can choose intervals in the data to find differences and rates of change.
The GAMI lean test has become the standard for checking the balance of the fuel injectors and to identify problem cylinders. When a user has conducted a GAMI lean test during a flight, the software will automatically calculate the GAMI spread for each test.
Savvy Goes Pro
After six months, Savvy Analysis offered a “Pro” service—after paying $129 ($199 for twins)—a price that hasn’t changed—for an annual subscription, a customer who uploads data can have as many flights as he or she wishes analyzed by one of Savvy’s analysts—within reason (at some point there is no added value and the cost to Savvy becomes too high). The Savvy analyst then generates a two-page report on the engine health on each flight. (The Savvy Analysis Pro service is included in the price of the managed maintenance service offered by SAMM.) Full disclosure, I own part interest in an aircraft that is a Savvy Analysis Pro customer.
Both Wrather and Busch recommend having the engine monitor data from a flight analyzed just before the airplane is going into the shop for engine work—to identify any problems so they can be fixed on that shop visit—and after work has been done on the engine, ignition, mags or induction system.
They also recommended that the flight to be analyzed not just be a routine cross country, but a test flight made according to the protocol on the website—essentially a GAMI lean test at less than 65 percent power and a lean of peak mag check to check the ignition system when it’s under the most stress.
Doing a test flight before a shop visit, uploading the engine data to Savvy Analysis and then clicking on the little “Sigmund” icon requests full analysis of that flight and generates a printed report that can be provided to the mechanic who is about to work on the airplane. It’s a fast diagnostic tool and much cheaper than trying to uncover such things as incorrect fuel flow, exhaust and induction leak, and mistimed mags when the airplane is sitting on the ground.
FEVA
Next, Savvy Analysis added an automatic service for its Pro customers (which includes all managed maintenance customers of SAMM)—Failing Exhaust Vale Analytics (FEVA). When you upload your engine monitor data, Savvy’s system automatically scans the EGT temperature readout and uses a proprietary algorithm to look for a signature that is indicative of a failing exhaust valve. If the characteristic pattern exists, the software flags it and starts the process that results in a warning to the owner and recommendation to borescope the cylinder.
FEVA came about as a result of observations Mike Busch made of engine monitor data more than 10 years ago. He noticed that for as much as 150 hours of engine operation prior to the time an exhaust valve fails, it generates a distinctive EGT pattern—an approximately one minute-long cycle over a 30- to 60-degree range.
He noted that the rotator cap that sits on the top of the exhaust valve stem—between the rocker arm and valve—and rotates the exhaust valve a fraction of a degree every time the valve opens and closes, causing about a one RPM rate of rotation of the valve. The purpose of the rotator cap is to spread the heat load on the exhaust valve around its circumference so one spot isn’t always being exposed to maximum heat. Rotation also helps inhibit buildup of exhaust deposits on the valve seat. (There is no rotator valve on the intake valve as it is not exposed to the same heat or exhaust deposit potential and the exhaust valve.)
As an exhaust valve starts to go south, becoming a burned valve, it develops a hot spot where it is not sealing perfectly with the seat—very hot gases from a combustion event begin to leak past the valve. Metal erosion begins and the valve can warp—causing the hot spot to get hotter and more gases to leak. Once it starts, the valve progressively goes downhill.
Ultimately, the valve will fail and a chunk of metal from the area of that hot spot breaks off, the cylinder goes to zero compression and stops combusting—the little piece of metal departs through the exhaust system. If it’s a turbocharged engine, it’s the luck of the draw whether the piece processes through the turbocharger, doing further damage, or the waste
gate directs it harmlessly out the tailpipe.
Borescope It
Burned valve damage is typically visible through a borescope between 50 and 150 hours prior to failure. A compression test is far less reliable, according to Busch, giving too many false positives. The borescope is the gold standard for determining impending valve failure—and the engine monitor is the early warning system that says when it’s time to do the borescope exam.
The picture that a failing exhaust valve paints on the EGT graph of engine monitor data is a slow, perfectly rhythmic oscillation of the EGT for the affected cylinder. Busch said, “The pattern is easily distinguishable from EGT data ‘noise.’ There isn’t anything else in the engine that can oscillate that slowly. Normally the amplitude is pretty small. We normally look for an oscillation of 30-60 degrees from peak to peak. When we see it, we know the valve is failing.”
Busch and his team developed an algorithm that spots this pattern in engine monitor data. As part of the subscription price for SAMM or Savvy Analysis Pro, a customer’s engine data is automatically put through the FEVA algorithm when the engine monitor data is loaded.
If the algorithm finds a failing exhaust valve, the analysts at Savvy are notified immediately. If they determine that there is a risk of a failing exhaust valve, one of them contacts the customer. Wrather says that the plan is for the system to automatically notify the customer in the future—right now they’re tweaking the algorithm and it’s tweaking itself through the process of machine learning, so they’re keeping an analyst between the computer and the customer.
The customer is advised that Savvy has detected what they believe is a failing exhaust valve, and which cylinder is involved. Savvy recommends to the customer that he or she have the affected cylinder borescoped. Savvy also requests that the customer send copies of any images made of the affected valve to Savvy, both for feedback to fine tune the algorithm and to let Savvy personnel look at the condition of the affected valve.
Busch said that Savvy will never recommend that a customer pull a cylinder based on FEVA alone—the borescope is the final diagnostic instrument for that decision. If the borescope reveals a valve that is exhibiting the characteristic asymmetric appearance and discolorations (green is bad) of impending failure, Savvy recommends that the cylinder be pulled and revalved.
Busch noted that few A & P mechanics have been trained in using a borescope and interpreting what they see. He strongly recommended—and we concur—keeping a copy on hand of the full-color poster put together for the Air Safety Foundation by Adrian Eichhorn and Dr. Peter Wu that shows healthy and deteriorating exhaust valves.
Alerts
Once a customer, either using the free service or Savvy Pro, has uploaded enough data for the system to have a solid operating history of the airplane, the system will automatically generate alerts that are sent to owners—Wrather said Alerts focus on conditions that Savvy believes warrant an owner’s attention such as high CHT or low oil pressure. The Alert advises of the condition, why Savvy feels that warrants the owner’s attention and what could be causing the condition so that it can be troubleshot and corrected.
Report Cards
The newest service from Savvy Analysis—for Pro Customers (again, we’re impressed that the services available have expanded and the price has stayed constant) is the issuance of a report card for the owner’s airplane. Once the owner has uploaded enough data to be statistically significant—Chris Wrather makes that decision, he’s got the Ph.D. and statistical analysis was a major part of it—the system generates a report card that is emailed to the customer. The report card reports on and analyzes 10 to 12 critical flight parameters related to performance, efficiency and engine longevity. It compares those parameters to those generated by other aircraft of the same type that provide data to Savvy.
Using a “thermometer” each parameter is mapped to show the maximum, minimum and median (not average, because outlier data tend to throw off averages in these circumstances) for the subject airplane. That line is then overlain on the low to high data generated by all of the airplanes in the cohort into which the customer’s airplane fits (for example, all Cessna T210Ls).
Going through the various parameters (and Savvy has added additional parameters in the last six months), the owner can rapidly see where his or her operations place the airplane compared to a stated number of flights made by a stated number of airplanes. More specifically, the owner can tell that if her median power setting is 66.9 percent, where it fits in with the power settings selected by other pilots in their airplanes of the same type. In an example we looked at for 4657 flights of a cohort of 413 Cessna 182 Skylanes, that power setting was right at the average for all of those flights.
The Report Card goes on to compare how the speed generated by that power setting matched with speeds of the other airplanes using the same power setting as well has how the CHTs, oil pressures, oil temperatures fuel efficiency and even amount of inactivity of the airplane matched with its cohort. The Report Card also includes a comment on the specific airplane versus the overall data generated by its cohort for each set of performance data—and can be a warning of developing problems. In the Cessna 182 sample we looked at, the airplane’s power setting, cruise speed and average CHTs were right in the middle of the data for all of the airplanes in the cohort, but maximum CHT spread was in the 96th percentile, which may warrant examination into a cylinder that is running hot.
Upload the Data
Savvy is working to get its clients to upload engine monitor data regularly—just as they send oil out for analysis at every change—not just when they think they have a problem.
Busch and Wrather also recommend a flight test, data upload an analysis before the annual inspection, before any engine work and after engine work. Having a printout of the engine’s health to hand to the mechanic who’s going to be head first into your airplane’s cowling can, in our opinion, save money by letting him or her fix small problems before they become large.
One of the side effects collecting data on what will soon be 2 million flights is that Savvy is publishing the overall results (not individual aircraft data, that is kept private) so that the general aviation community as a whole can learn more about how our airplanes are being operated and how they respond in operation.
We like the Savvy Analysis concept—the FEVA and new report card program is, to us, additional protection at no extra cost. We also like the fact that the basic Savvy Analysis program is free, so owners can upload data and do their own analysis using the tools on the site.
Savvy Analysis is at www.savvyanalysis.com.
Rick Durden is a CFII, holds an ATP with type ratings in the Douglas DC-3 and Cessna Citation and is the author of The Thinking Pilot’s Flight Manual or, How to Survive Flying Little Airplanes and Have a Ball Doing, Vols. 1 & 2.
