Video: Max-Viz EVS600 Flight Evaluation
  • The Astronics Max-Viz Enhanced Vision system displays a real-time video of the aircraft's external environment using infrared and visible light cameras.
  • It is available as a factory option for many G1000 aircraft and has STC approval for retrofit on most Cessna singles.
  • Aviation Consumer's Larry Anglisano conducted an evaluation of the system in a Cirrus aircraft.
The Astronics Max-Viz Enhanced Vision system uses an infrared sensor and a visible light camera to display a real-time video image of the environment outside of the aircraft. It’s available as a factory option for many G1000 aircraft, plus it has STC approval for retrofit on most all Cessna singles. Aviation Consumer‘s Larry Anglisano evaluates the system in a Cirrus.
