Pro Star Aviation received approval from the Federal Aviation Administration (FAA) January 5, 2017, for STC ST00373BO – Installation of Rockwell Collins TDR-94D Transponders with ADS-B Out.
In partnership with Rockwell Collins, Pro Star Aviation designed an STC to address ADS-B compliance for the vast number of aircraft equipped with BendixKing MST-67A transponders associated with the BendixKing CAS-67A or B TCAS II system.
Currently, BendixKing does not offer an upgrade program for MST-67A units to comply with ADS-B. Since the MST-67A transponders are a vital component of the CAS-67A TCAS II system, it is important to retain the integrity and approval of the existing TCAS installation while making the aircraft compliant with the 2020 ADS-B mandate.
Since the Rockwell Collins TDR-94D transponder is the only non-integrated transponder approved in the BendixKing installation manual that is compatible with the CAS-67, Pro Star determined it to be the best replacement for the non-compliant MST-67A transponder.
The design of the STC, utilizes a pair of Rockwell Collins TDR-94D units that fit in the same location as the MST-67A units. The existing wiring, antennas and the controller can be retained. In its new configuration, the TCAS system is both manufacturer tested and STC approved to be fully compliant using the new transponders.
The STC features an Approved Make and Model List covering, but not limited to, the following MST-67A equipped aircraft; Hawkers, Challenger, Falcons, Gulfstreams, Westwards, Saberliners and Citations.
While there are other solutions to replace the outdated MST-67A units, only the Rockwell Collins TDR-94D solution has been a BendixKing approved option for the CAS-67A TCAS II system since the system was first offered nearly two decades ago.
According to Pro Star Aviation’s Director of Business Development, Jeffrey Shaw, “This STC is particularly useful in situations where there is concern for the integrity of the existing TCAS II system when changing transponder manufacturers in order to comply with ADS-B.” The FAA has indicated that upgrading transponders to comply with ADS-B will not compromise the integrity of the existing TCAS, however changing transponder manufacturer all together is not specifically covered by the spirit of the FAA’s statement. Jeffrey went on to say, “We are very pleased to be able to use a transponder type covered in the original BendixKing installation manual. The TDR-94D is the only model that meets the ADS-B mandate and is covered by the CAS 67 installation manual.”
For additional information, STC purchase, or to schedule an installation, please contact Pro Star’s Sales Department at (603) 627-7827.
ABOUT PRO STAR AVIATION: Pro Star Aviation specializes in business and corporate aircraft installations, maintenance and modifications. The company offers; avionics service and installations; major alterations and repairs; STC development and certification service; AOG support and service; Part 135 and 91 aircraft management service. Its main facility, located at the Manchester-Boston Regional Airport (MHT) in Londonderry, NH, serves customers on-site and on-location throughout the Northeast United States. www.prostaraviation.com
