BlackFly Multirotor Makes AirVenture Debut
  • The Opener Inc. BlackFly is an ultralight, electric personal multirotor aircraft designed for commuting, demonstrating significant progress and extensive testing.
  • It boasts eight electric motors, triple-redundant control systems, and unique canted wings for efficient flight, achieving speeds up to 62 MPH and a range of approximately 25 miles.
  • Emphasizing safety, the BlackFly includes features like auto-land, a "go to home" function, and a ballistic parachute, backed by over 500 test flights with programmed failures.
  • Version three of the BlackFly is slated for release in 2019, with its price expected to be comparable to that of an SUV.
The concept of home-to-office personal flight is sweeping the nation, and it seems multirotor ideas are cropping up each week. The Silicon Valley startup VTOL BlackFly is showing particular promise, and recently demonstrated flying prototypes under the ultralight category. It arrived at aviation’s Mecca this week.
Marketed by Opener Inc., the carbon-fiber BlackFly is equipped with eight electric motors. Each motor weighs four pounds and generates 130 pounds of thrust. Opener reps say the company has been testing motor-rotor sets for more than three and half years, covering a distance equivalent to 20 circumnavigations of the globe. There are two batteries per each engine-rotor pod, and they’re constantly being monitored.
“The control systems in each wing are triple redundant, leaving room for system failures,” said Alan Eustace, director and salesperson for Opener Inc. Eustace served as senior vice president of knowledge at Google, and has held the world record for highest-altitude free-fall jump since Oct. 24, 2014.
The BlackFly is restricted to 62 MPH in the United States. The BlackFly’s unique canted wings fore and aft provide lift in level flight, easing the burden on the lift rotors. With a 25 percent reserve, it can fly for about 25 miles before a recharge. With a regular 110-volt outlet, it can chargein seven hours, and in only one hour using a 220-volt outlet.
While version three has not yet flown, version two has made more than 500 takeoffs and landings, often with worst-case-scenario engine failures programmed into the test card.
“It was built completely with safety in mind,” Eustace said. Like a modern drone, the BlackFly has a “go to home” feature, and also auto-land and a ballistic parachute.
Version three of the BlackFly will be available for purchase in 2019. While it does not yet have a price, Eustace said it will be “competitive with the price of an SUV.”
For more information go to www.opener.aero.
