Airbus Planning Open Rotor Engine For A320 Replacement
CFM
  • Airbus is considering an open rotor engine, developed with CFM, for its A320 replacement, aiming for a 20% reduction in fuel burn through a larger bypass ratio.
  • The new single-aisle aircraft may feature folding wingtips, inspired by the Boeing 777-X, to enable longer, more efficient wings while fitting existing airport infrastructure.
  • Engineers are working on adapting these technologies for smaller aircraft, with Airbus targeting the new aircraft's service entry within the next 15 years.
Airbus says it is considering using an open rotor engine on its replacement for the A320. The company has been working with CFM to develop the engine, which has primary and secondary counter-rotating turbine vanes on the outside of the engines rather than being encased in a nacelle. Exposing the turbines makes the bypass ratio a lot bigger and that improves efficiency.
CFM spokesman Mohamad Ali said they’re expecting a 20% reduction in fuel burn by the new engine. That is the fuel burn opportunity that we are thrilled and excited about,” Ali told Simple Flying. “And it is not a vision in the future. We have done hundreds of tests already to demonstrate that project.” The engines will make a different noise than conventional jets but won’t be any louder, he said.
The new single-aisle design may also borrow a concept from Boeing 777-X and come with folding wingtips. Long thin wings are more efficient at altitude but airport ramps and gates aren’t set up for them. Boeing solved the issue by folding up the outermost 8.6 feet of the wings. Airbus told Simple Flying that it’s actually harder to make the folding wings work on smaller aircraft and engineers are working on it. Airbus hopes to have the new aircraft in service in the next 15 years.
