Frosty Peril
With the arrival of Fall comes morning frost in many parts of the country. Frost is dangerous when it adheres to airfoils such as wings, control surfaces, propeller and rotor blades because even a thin and nearly invisible layer of frost can degrade lift catastrophically. In this timely article, AVweb’s safety editor Brian Jacobson discusses how you can protect yourself from this serious threat.
91.527 Operating in icing conditions.
   (a) No pilot may takeoff an airplane that has -
      (1) Frost, snow, or ice adhering to any propeller, windshield, or powerplant installation or to an airspeed, altimeter, rate of climb, or flight attitude instrument system;
      (3) Any frost adhering to the wings or stabilizing or control surfaces, unless that frost has been polished to make it smooth.
Frost will occur when the surface temperature of an airplane is below freezing andbelow that of the dewpoint (which must also be less than 32 F). It usually forms earlyin the morning, and melts away as the temperature rises with the heating of the day andexposure to sunlight. However, if the temperature remains below freezing, and sunlightfails to heat the surface of the airplane, it is up to the pilot to be certain that stepsare taken to clear the frost from the aircraft before flight is attempted.
Many pilots look at the wing surface and say there is no appreciable change in itsshape, or that the amount of frost that has gathered is not appreciable. What they don'tunderstand is that frost, because of the surface roughness created by its jagged crystals,may disrupt the flow of air across an airfoil enough to destroy a great deal of its lift.That makes flight at slow speeds, during landing and takeoff, hazardous, as the pilot of aCessna T210 found out one November morning in 1994.
An Ill-Fated Frosty Departure
The airplane was parked overnight at the Isabel Valley Airport at Mount Hamilton,California. The pilot reported to investigators that he began his preflight activityaround 0700 (PST) in preparation for flying his three passengers back to San Jose.
The weather was clear and cold. The pilot stated that he found nothing unusual duringhis walk-around inspection. He said there was no ice on the leading or trailing edges ofthe aircraft, the flaps, horizontal stabilizer or on the fuselage, though there was someon the windshield.
The pilot started the engine for a few minutes, and while he was warming it up hispassengers arrived. He shut the engine down and boarded his passengers. At this time hetried to clear the frost from the windshield, but was not successful. A passenger offeredsome hot tea to pour on the window, and the pilot used it. The pilot then reboarded theairplane, restarted the engine, allowed it to warm up for ten minutes, then taxied out. Hesaid there was no frost on the windshield at that time.
The dirt runway at the private airport was 3,000 feet long and 35 feet wide. The pilotbegan his takeoff roll at 0720. He said he rotated at 80 miles per hour and established anormal rate of climb. At that time the windshield began to "glaze over," and at100 feet AGL the pilot could no longer see out of it. He raised the nose for a few secondsto be certain he climbed over the obstacles he knew were at the end of the runway.
By the time he reached 200-250 feet AGL he felt the engine was only at about 60 percentof its power output. The pilot dropped the nose to prevent a stall from occurring andbegan to descend while trying to increase airspeed. The aircraft dropped to the left, buthe was able to keep it from spinning by using right rudder and leaving the power on. Ahigh nose attitude was maintained to keep the airplane from dropping to the ground nosefirst. The aircraft's left main gear was ripped off when the aircraft touched down to theleft of the runway on hard terrain. The airplane skidded about 100 feet before coming to astop. All aboard suffered minor injuries.
At least one of the passengers did not agree with what the pilot told investigators. Hesaid that the airplane had frost on all of its exposed upper surfaces, and that the onlyeffort that was made to clean it off was the hot tea poured on the windshield. He feltthat the takeoff was normal until the airplane climbed to about 100 feet AGL, and that theengine sound did not change from the time full power was applied until the airplanedescended back to the ground.
What probably happened is that the pilot, unable to see through the frost coveredwindshield rotated the airplane to too high a nose attitude, and the frost on the airframecaused the airplane to stall at a higher than normal airspeed. The attitude that wasrequired to clear the obstacles at the end of the runway did not help matters. All aboardwere lucky that the airplane did not spin into the ground, because stall spin accidentsfrom that altitude are normally fatal.
Had the pilot attempted to keep the airplane climbing by rotating the nose even higher,a typical response in a situation like that, the accident probably would have been moredevastating for those aboard. No doubt that the use of the right rudder and the continuedapplication of full power helped to minimize the injuries.
How Much Frost Is Too Much?
How much frost was on that aircraft? There is no consensus on that. The passenger didnot offer any comment on how thick it was, and the pilot claimed it wasn't there. But itdoesn't take much to change the aerodynamic affects of the airplane, to the point where itis not controllable.
So, before you go blasting into the sky this fall and winter be sure your airplane isclear of all frost, snow, and ice. The best way to do that is to move the airplaneinto a warm hangar and let it melt off. But before the airplane is pulled back outside itmust be dried thoroughly or ice will form on the wet surfaces. And be certain that nowater is left anywhere around the moveable control surfaces that could freeze and restricttheir movement when the airplane is taken outdoors.
Another way to deal with frost is with deicing solutions such as alcohol or glycol. Butkeep in mind that these liquids offer protection that is short-lived, and that theyprovide no protection at all from frost that may form where the fluids cannot reach.
One winter I had a Cessna 402 defrosted in a warm hangar, and we dried the fuselage andwings thoroughly before pulling the airplane back out into the sub-zero temperatures.After loading my passengers we departed Lincoln, Rhode Island for Teterboro, New Jersey,but after takeoff as I tried to raise the landing gear they would not retract. The greenlights remained on, so I returned to the airport for an uneventful landing. Water hadcondensed inside a faulty "squat switch" on one of the main gear then froze whenthe airplane was pulled back outside. The frozen switch would not let the gear retract.
FAR 91.527(a)(e) suggests that it's okay to take off with frost on an airplane so longas it has been "polished smooth." But what exactly does that mean? Is itpossible for a pilot to insure that as he or she "polishes" the frost that theshape and smoothness of the airfoil is exactly the same as if there were nothing on it? Ifind that hard to believe. The best way to be sure there will be no unusual handlingcharacteristics that could lead to any kind of incident is to remove all ice, frost orsnow from the aircraft before any attempt to fly is made.
Frost You Can't See
The same conditions that cause frost to form on the outer surfaces of the aircraft cancause internal problems as well. If moisture condenses inside partially filled fuel tanksthen freezes as the outside temperature drops, the resulting ice can block the flow offuel to the engine. If your airplane is kept outdoors take precautions to avoidcondensation. Top the fuel tanks, and be certain you drain a sufficient quantity of fuelfrom the tanks before flight that will assure you that there are no problems with the fuelflowing from the tanks.
Any moisture that is inside the fuel tanks, no matter its source, can freeze once anairplane is towed back outdoors. Leave the aircraft inside long enough for its temperatureto modify then drain all of the fuel tanks until no water comes from the tanks. If a largeamount of water is found get a mechanic to check the entire fuel system before departure.On airplanes with rubber bladder tanks water can be trapped in wrinkles at the bottom ofthe tank, and may slosh around when the airplane is being moved or is in flight. If thatwater freezes in the wrong part of the tank you might experience fuel starvation.
So, before you fly an aircraft that has a covering of frost on it, be sure it iscleaned thoroughly. Don't take any chances, no matter how little frost is on the airplane.
