Aerox Oxygen Air Venture Promotion
Aerox Oxygen Systems will be offering a 20% Off Promotion for Portable Oxygen Systems Purchased at EAA Air Venture 2018
Shaw Aerox(R) Aviation Oxygen Systems will provide a Portable Oxygen System Promotion during EAA Air Venture 2018
Press Release: Air Venture 2018 FOR IMMEDIATE RELEASE
Bonita Springs, FL. & Oshkosh, WI, June 14, 2018 Shaw Aerox(R) Aviation Oxygen Systems will be offering a promotion of 20% off list price for all Aerox portable oxygen systems and components purchased during the EAA Air Venture in Oshkosh, Wisconsin, July 23 - 29, 2018. Included in this promotion is a free oximeter and seat back carry pouch with every purchase of a portable oxygen system.
Shaw Aerox will also be displaying the latest in Oxygen System Technology with several unique products designed by Aerox engineers to improve the flying experience for the pilot and passengers at the Shaw Aerox Aviation Oxygen Systems Booth, Number 2080 in Exhibit Hangar B, Aisle D. Oxygen, essential for human life, is abundant at ground level. As flight levels increase, atmospheric pressure decreases, necessitating the requirement for supplemental oxygen. Shaw Aerox Portable Oxygen Systems , which are compact and exceptionally light, can be configured to meet customers' individual requirements and are ideal for pilots that frequently rent or use aircraft that are not equipped with built in oxygen systems.
The Aerox PrO2 - 2, PrO2-4 and PrO2-6 Personal Emergency Oxygen Systems provide take anywhere convenience and safety at a reasonable cost. Multiple configurations, depending on number of pilots and passengers, can be provided to suit your needs. The systems are designed to deliver oxygen based on a cabin pressure of 25,000 feet and will flow oxygen at a predetermined rate from 17 to 60 minutes, depending on system configuration, to allow descent to a safe altitude where you can breathe normally under current conditions.
Simple to use when needed, just pull the mask and don. The motion of pulling the mask pulls a cable to activate the flow of oxygen. The systems come with aluminum DOT-3AL cylinders with no life limits and a 5 year recertification requirement.
If you can carry a soft drink can, you can carry the Aerox PrO2 Personal Safety System.
Page 2
Shaw Aerox also offers a complete line of FAA-PMA (Parts Manufacturer Approval) cylinder assemblies available as direct replacements for most aircraft.
Available in either Kevlar(R) composite fiber wrapped (5 year hydrostatic tested with 15 year service life) or steel cylinders per DOT 3HT and TC-3HTM (5 year hydrostatic tested with 24 year service life).
Manufactured and cleaned specifically for aviation oxygen service, Aerox cylinders are offered in a number of sizes and capacities depending on the airframe's original equipment specifications. Complete cylinder and valve assemblies are also available.
Shaw Aerox also offers other emergency system options as well as a full line of portable and built in oxygen systems.
About Aerox(R) Oxygen Systems, LLC Shaw Aerox(R) Oxygen Systems, LLC designs and builds innovative, high-duration oxygen systems made specifically for the aviation industry. Since 1981, pilots and passengers around the world have depended on Aerox O2 aviation masks, cannulas, cylinder tanks, portable oxygen and emergency oxygen systems to keep them healthy, alert and safe in the air.
Our ISO9001:2008 Stage 2 audit has been passed and the auditors (CIC Management) have confirmed to the registrar (DAkkS) that Shaw Aerox, LLC has an acceptable Quality Management System and has been provided with ISO9001:2008 accreditation. Shaw Aerox is unique in the aviation oxygen systems field as the only manufacturer receiving this distinction. In addition, Shaw Aerox Oxygen Systems, LLC has achieved AS9100 Quality Certification and our Repair Station is approved under FAA Part 145 certification requirements for maintenance, repair, inspection and recertification of Shaw Aerox Oxygen products. For more information about any of our products or to learn more about our custom system design capabilities, please visit www.aerox.com, call 1-800-237-6902 or email Aerox@aerox.com ###
Media Contact: John Barone Shaw Aerox, LLC 25190 Bernwood Drive Bonita Springs, FL 34135 www.aerox.com jbarone@aerox.com +1.716.560.7596 (24/7)
