B-21 Powered Up In Advance Of First Flight
The B-21 Raider was unveiled to the public at a ceremony December 2, 2022 in Palmdale, Calif. Designed to operate in tomorrow's high-end threat environment, the B-21 will play a critical role in ensuring America's enduring airpower capability. (U.S. Air Force photo)
  • Northrop Grumman has powered up its first B-21 stealth bomber and anticipates its inaugural flight later this year, though the exact timing is flexible.
  • The B-21, last seen during its December unveiling, will proceed directly to Edwards Air Force Base for private testing after its initial short flight.
  • Low-rate initial production is expected to commence next year, with the Air Force planning to acquire 100-200 aircraft, each currently estimated at $692 million.
Northrop Grumman says it has powered up its first B-21 stealth bomber in advance of a first flight that is still being forecast for later this year. The top-secret program came up in an earnings call last week, and top Northrop executives indicated the program is more or less on schedule. “We remain on track for first flight this year,” said CFO David Keffer. “Again, that timing continues to depend on events and data over time.”
Northrop Grumman unveiled the B-21 last December, saying it was going to be visible on the runway at its home airport in Palmdale in California’s high desert. But the plane hasn’t been seen since and there have been some delays announced in that time. When the B-21 does finally fly, it won’t be for long. It will head directly to Edwards Air Force Base, about 40 miles away, where the manufacturer and the Air Force can wring it out in private. Low-rate initial production of the aircraft is expected to begin next year. The Air Force has ordered 100 aircraft initially and could buy as many as 200 at a current cost of $692 million each.
