Owner-Performed Maintenance
I’ve always been fond of pointing out one of the most dangerous things in personal aviation is a private pilot with a #2 Phillips screwdriver. That’s because I’ve occasionally come across the aftermath of an owner who tried but failed to accomplish a simple inspection or maintenance task without the proper knowledge, tools or training. Too often, the results demanded a “real” mechanic to come in and fix the mess. And, while I’ve tried to do as much preventive maintenance on my airplane as I can, I’ve often gotten in over my head and needed some professional assistance, too.
Thankfully, the FAA still allows certificated pilots to work on their aircraft, performing some relatively mundane tasks. At the same time, the relevant regulations are broadly written and can cost the unsuspecting pilot/owner more in the long run than if a professional, certificated mechanic is allowed to do the work. Let's explore some of the ways we can get in over our head, and how to avoid it.
Tools And Equipment
The aforementioned #2 Phillips screwdriver is a common tool, both around the house and the hangar. And a lot of work -- especially removing inspection covers or landing light lenses, for example -- easily can be accomplished with one. But when it comes to reassembling the airplane -- or even dealing with a stuck fastener, that simple screwdriver isn't going to be enough, and actually may be a liability.
One of the most-common preventive maintenance tasks owners perform is changing the engine oil. On my airplane, I need a bucket, a large-diameter hose, an appropriate wrench to remove the oil filter, a Dzus tool to open up the cowling and a flat-blade screwdriver to loosen the plug on the quick-drain hose. I also need a supply of safety wire and safety-wire pliers. Engines not equipped with a quick drain -- or when a spin-on oil filter isn't installed -- also may require a torque wrench to reinstall the drain plug or the oil screen after cleaning. The well-equipped hangar should have all these items readily at hand.
Meanwhile, the well-prepared owner/pilot also should know how to use these items, preferably after his A&P shows him the ropes. For example, wailing away on a spark plug with a long-handled wrench without paying attention to when the manufacturer's torque specifications have been reached can damage a perfectly good cylinder, sometimes requiring its removal to repair the threads and remove metal shavings.
Another operation where the proper tools are worth their weight in gold comes when attempting to jack the airplane and either perform maintenance on the wheels and tires or swing a retractable's landing gear. If you fly a small, light taildragger, you can probably get by with an automotive-grade hydraulic jack and a suitable adapter to raise one main wheel at a time. But the average tricycle gear airplane -- especially one sporting a high-mounted wing -- can require purpose-designed jacks. You may also need some kind of weighted tailstand, to ensure the nosewheel stays off the hangar floor and the nose doesn't pitch over if you need to climb in or out.
In any event, lifting the average tricycle-gear airplane on jacks should be a two-person operation -- with one on each main-gear jack -- to ensure each wing is raised more or less at the same time and the airplane remains level. It never hurts to have that extra set of hands, or eyes. And, when the airplane is high enough off the hangar floor, don't forget to use the jack's locking feature. Your jacks do have a locking feature, right?
References
Too often, I see owners trying to tackle a simple task without the appropriate information at hand. A common example is not knowing the appropriate torque values for, say, changing spark plugs or using an incorrect lubricant on the airframe. Instead of acquiring and using the appropriate maintenance reference materials, they depend on the airplane's POH or a hangar neighbor's recommendations. Both can be woefully inaccurate.
In addition to the aforementioned torque specifications for spark plugs and the like, common information available in a manufacturer's maintenance documentation can include detailed procedures for servicing, removing and reinstalling various components, even those the FARs allow owner/pilots to work on without references. Adding oil and/or air to landing-gear struts is a great example, since the internal pressures involved can be much greater than expected.
The FARs also allow repairing broken landing light wiring circuits, replacing and servicing batteries and replacing position and landing lights. Does your POH/AFM include a detailed wiring schematic diagram? The appropriate maintenance manual does. Do you know what size wire is appropriate? You'll find that in the FAA's Advisory Circular AC 43.13-1B, Acceptable Methods, Techniques, and Practices -- Aircraft Inspection and Repair. Does your POH/AFM include a list of the circuit codes often printed on the wires themselves? That's something else you can find in the manufacturer's maintenance manual.
Another area where appropriate reference materials should be considered mandatory is when deciding on the appropriate lubricants, fluids and preservatives. Many POH/AFM references include details on where and with what the airframe should be lubricated periodically. But those details can change over time and a product commonly available 50 years earlier when your aircraft was manufactured may no longer be available. There's simply no way to know what changes may have been made to the manufacturer's maintenance recommendations without obtaining and using current documentation. The sidebar on the opposite page highlights some reference materials you may wish to consider.
Knowledge and Training
Perhaps one of the most important items you need before performing preventive maintenance on your aircraft is the appropriate knowledge and training. By itself, owning a pair of safety-wire pliers doesn't mean you can properly secure your spin-on oil filter after replacing it.
Ideally, before we tackle a preventive maintenance procedure, we'll ask our A&P-IA or someone else with the appropriate knowledge and experience to show us the ropes. Another resource is the many type clubs offering owner/pilots varying levels of training in performing preventive maintenance on their airframes. Engine manufacturers also offer related courses, though they're typically geared toward the certificated mechanic. And your local community college or continuing education institution may also provide appropriate training.
In our experience, however, the best way to learn how to do these things is to go the owner-assisted annual inspection route, presuming your shop or IA allows it. You'll spend at least a couple of days on the hangar floor opening inspection panels, get extremely dirty and have a few more aches and pains at the end of it. But you'll also learn a lot about your airplane, and where some of its looming problem areas might be in the future, but which can be deferred for now. Most important, you'll have the opportunity to perform many of the tasks allowed under the FARs while your IA looks on, learning how and how not to use the appropriate tools in the process. That experience is invaluable if you plan to do any preventive maintenance yourself. Finally, don't forget to make the appropriate logbook entries.
Conclusion
Personal aircraft aren't falling out of the sky each day because their owners didn't use the manufacturer's recommended grease in the wheel bearings. But most of us didn't go through the process of becoming pilots because we lack attention to such details, either.
While there's certainly the safety issue of screwing up one of the preventive maintenance tasks the FARs allow, using the correct tools, supplies documentation and other items recommended or required to maintain your aircraft helps preserve it and minimize the overall cost of ownership. By getting up close and personal with many of these tasks, we not only learn more about our aircraft, but can more easily diagnose what a new noise or vibration might mean. And with the extra money we save from performing a lot of these tasks ourselves, we can afford more training and get more utility from the aircraft. It's all good.
Preventive Maintenance Gotchas
The FARs allow pilots lacking a mechanic's certificate a great deal of flexibility in performing work on their airplanes. But before deciding to tackle an allowed task, pilots need to ask themselves if they have the knowledge, training, tools and workspace to reliably and safely complete it. Following are some tasks the FARs allow, along with some thoughts on what can trip up the average owner/pilot.
Changing Tires
Changing a tire on most aircraft is a relatively simple process: Jack the airplane, deflate and remove the tire, disassemble the wheel, clean it, lubricate the bearings and reinstall. But jacking requires the appropriate equipment, especially when considering a high-wing airplane, or when replacing a nosewheel tire. Also, do you know what the red and yellow dots on the sidewall indicate?
Refinishing Fuselage/Cabin
Pilots often interpret this task to mean they can strip and repaint their airplane by themselves, or refinish an interior. That's technically true, but careful thought must be given to the tools, materials and process. For one thing, the aluminum sheet metal used in airplanes can easily corrode unless it's been properly treated before paint is applied. And even professionals installing upholstery panels near pitot-static lines or antenna cables have been known to damage a related system.
Replacing Fasteners
One of the more popular things an owner can do is replace exterior hardware with new fasteners, preferably stainless steel. The trick comes in determining what's nonstructural and what isn't. Using a nonstructural fastener in lieu of the real thing can mean losing a fairing -- or worse -- in-flight. And removing stuck fasteners without damaging the surrounding structure can be a major undertaking.
Updating Databases
Every 28 days, a new database is issued and can be used to update the avionics in our panels. There's nothing delicate or special about the procedure, and thousands of pilots manage to accomplish it each month. But do you also remember to update the aircraft's logbooks, as required?
This article first appeared in the March, 2011 issue of Aviation Safety magazine.
