Northrop Grumman Test Flies Jam-Proof GPS
Northrop Grumman says it’s successfully flight tested a jam-proof navigation system to replace the current gear on military aircraft. Embedded Global Positioning System (GPS) / Inertial Navigation System (INS) Modernization,…
Northrop Grumman says it's successfully flight tested a jam-proof navigation system to replace the current gear on military aircraft. Embedded Global Positioning System (GPS) / Inertial Navigation System (INS) Modernization, known as EGI-M, was installed on a Cessna Citation and put through its paces in May. The core of the system is something called an M-Code capable GPS receiver that can "quickly transmit positioning, navigation and timing information" in "GPS-contested and GPS-denied environments."
The new systems are designed to drop in to replace existing GPS systems and the first aircraft to receive them will be F-22s and E-2D Advanced Hawkeyes, but eventually all fixed and rotary wing platforms will get the upgrade. The EGI-M capability developed by Northrop Grumman enables our warfighters to navigate accurately and precisely through hostile and contested environments.”
