Senator Wants End To Forest Service Inspections Of Firefighting Aircraft
Forest Service inspections are redundant, says Montana Senator.
Bridger Aerospace
A Montana senator who founded one of the largest aerial firefighting companies in the U.S. is recommending the U.S. Forest Service end its practice of inspecting firefighting aircraft before the start of each season. Sen. Tim Sheehy, R-Montana, who stepped down as CEO of Bridger Aerospace to run for the Senate last year, says the Forest Service uses outdated methods and duplicates FAA oversight. Each year the Forest Service looks at every plane and checks the flight credentials of every pilot in a process called "carding."
“Agency carding of firefighting aircraft is a relic of a bygone era and has become an unnecessary barrier to asset availability,” Sheehy said. “With inspector shortages increasing year over year and shifting interpretation of standards, redundant carding has hindered aerial firefighting capability,” Sheehy said. “We are working to change the regulations to this effect, among many other changes, so that we can provide the maximum number of safe aircraft to the teams fighting fire when they are needed most.”
The Forest Service inspections were started after a spate of crashes in the 1960s and 1970s involving firefighting aircraft, most of which were converted piston airliners and military planes. The industry has changed significantly since then with modern designs and better engineered conversions being used for the job, which is in much more demand in the last couple of decades.
