The first on-ramp to the Highway In The Sky opens June 5. That’s when NASA’s Small Aircraft Transportation System (SATS) undergoes its first demonstration at Danville Airport in Virginia. While Boeing and Airbus work on bigger planes that can fly fatter … and farther … SATS is dedicated to creating infrastructure for point-to-point air travel that bypasses major airports and allows convenient and reliable access to thousands of small airports all over the country. SATS manager Jerry Hefner told graduateengineer.com that 93 percent of Americans live within 30 minutes of an underused rural airport (just don’t try to find hangar space there). The challenge is to increase the use of these uncontrolled airports without increasing the number of midairs and weather-related crashes. The June demonstration will feature a GPS-based onboard anti-collision system that allows pilots to track nearby traffic. SATS will also use GPS to create predetermined routes from airport to airport (the aforementioned highways) and employ enhanced vision systems to allow pilots to land safely in bad weather. Hefner is a frequent flyer on NASA’s fleet of bizjets and knows well the advantages of point-to-point travel over the airline hub-and-spoke system. “You don’t have to do that more than once or twice to appreciate the advantages. It reduces the hassle and saves time,” he said.
Future-Tech, SATS Test This Summer
- NASA's Small Aircraft Transportation System (SATS) aims to create infrastructure for convenient point-to-point air travel using thousands of underused small airports, bypassing major airline hubs.
- The initiative seeks to increase the use of these airports safely by implementing GPS-based anti-collision systems, predetermined "Highway In The Sky" routes, and enhanced vision systems for bad weather landings.
- The first SATS demonstration, featuring these technologies, is scheduled for June 5 at Danville Airport in Virginia.
- SATS promises to reduce travel hassle and save time compared to the traditional airline hub-and-spoke system.
