Britten-Norman To Support UK-based Airborne 5G Platform Test Program
Image: Britten-Norman
  • A UK research project, led by Stratospheric Platforms Ltd. (SPL) with support from Britten-Norman, aims to provide high-performance 5G service from the stratosphere using High-Altitude Platforms (HAPs).
  • The project concept involves developing an uncrewed, liquid hydrogen-powered aircraft designed to stay aloft for over a week.
  • Britten-Norman will commence flight trials in July 2024 using a modified turbine-powered BN2T Islander aircraft to test the 5G phased array and related equipment.
A U.K.-based research project, announced today, will explore the concept of establishing a High-Altitude Platform (HAP) with airborne antennas to provide high-performance 5G service from the stratosphere. The project is led by Stratospheric Platforms Ltd. (SPL), described as a non-terrestrial networks telecom developer, and aircraft manufacturer Britten-Norman will provide “key design and trials support” for the research, including use of a turbine-powered variant of its BN2T Islander twin.
The concept involves developing an uncrewed aircraft, powered by liquid hydrogen, that can stay aloft for more than a week at a time. Britten-Norman expects to begin flight trials in its modified Islander from its maintenance facility at Solent Airport in the U.K. starting in July 2024.
The Islander was selected for testing as part of the first phase of the program “due to its performance and payload capacity and the simplicity with which it can be modified to accommodate the equipment,” according to the announcement from Britten-Norman. The 5G phased array associated with the tests will be linked to the telecommunications and mission equipment installed in Suffolk, England.
Garnet Ridgeway, a flight test engineer for Britten-Norman, said, “This is a great opportunity to demonstrate the full capabilities of both Britten-Norman as an accomplished trials organization and the Turbine Islander as a highly capable trials aircraft … the BN2ST-4S Islander has a combination of payload capacity, endurance, climb performance, twin-engine reliability, robustness, and electrical power generation that makes it unbeatable for this mission.”
Mark Phelps
