China’s 19-Seat Electric Aircraft Completes First Piloted Flight
The CE-25A is designed for short-distance commercial flights and has a reported range of approximately 250 miles.
China's 19-Seat Electric Aircraft Completes First Piloted Flight
[Credit: Civil Aviation Administration of China]
  • COMAC successfully conducted the first piloted flight of its 19-passenger CE-25A electric aircraft, designed for short-distance commercial flights.
  • The CE-25A features a distributed electric propulsion system with 10 electric ducted fans and has a reported range of approximately 250 miles.
  • Having completed previous autonomous flights, the aircraft is now undergoing the regulatory review process with the CAAC for its type certificate before commercial service.
China’s Commercial Aircraft Corporation (COMAC) said it completed the first piloted flight of its CE-25A electric aircraft on Saturday, Nov. 14, in Binzhou, Shandong province. According to the Civil Aviation Administration of China (CAAC), two pilots and a flight-test engineer were aboard the aircraft, which operated normally and met expected performance targets.
The 19-passenger aircraft is designed for short-distance commercial flights between cities and has a maximum takeoff weight of approximately 22,000 pounds. COMAC lists a cruising speed of 162 knots, a range of approximately 250 miles and a cruising altitude of 7,900 feet.
Aircraft Development
The CE-25A uses a distributed electric propulsion system consisting of 10 electric ducted fans mounted above its wings. The aircraft was developed through a partnership between COMAC, battery manufacturer CATL, Shanghai Jiao Tong University and other organizations.
The aircraft previously completed its first uncrewed autonomous flight on Feb. 2 and has since undergone 19 autonomous flight validations. According to local reporting, Saturday’s piloted flight covered approximately 37.5 miles and lasted just under 17 minutes.
Certification Process
The CAAC has accepted COMAC’s application for a type certificate, beginning the regulatory review process required before the aircraft can enter commercial service. No anticipated certification or entry-into-service date has been announced. China previously certified the four-seat RX4E electric aircraft in January 2025 for commercial operations under its Part 23 regulations.
Matt Ryan
