CubCrafters Introduces New Engine For Experimental Carbon Cubs
Image: CubCrafters
  • CubCrafters has introduced the CC363i F/P, a new fuel-injected engine designed specifically for experimental Carbon Cub aircraft equipped with fixed-pitch propellers.
  • Compared to the older CC340 engine, it provides nearly a 5 percent increase in horsepower with only a 7-pound weight gain, alongside smoother operation, better cooling, improved fuel efficiency, and compatibility with Autogas and next-generation fuels.
  • Currently in the final stages of flight testing, the engine is slated to begin shipping as early as October exclusively for experimental Carbon Cub models, including the EX-2, EX-3, FX-2, and FX-3.
CubCrafters has unveiled a new engine designed for experimental Carbon Cub aircraft outfitted with fixed-pitch propellers. Called the CC363i F/P, the engine is a version of the 186-HP four-cylinder, fuel-injected, constant-speed prop CC363i introduced by CubCrafters in 2017. The Carbon Cub entered the market powered by CubCrafters’ Lycoming O-320-based carbureted 180-HP CC340 engine.
“It is exciting to be able to introduce this new engine to our customers,” said Brad Damm, CubCrafters vice president of sales and marketing. “This is an engine our customers have been specifically asking for, especially our kit aircraft customers. It’s simple to operate and has better overall performance than any of the other fixed pitch engines we offer. It’s smoother, more fuel efficient, and it cools better.”
According to CubCrafters, the CC363i F/P will offer a horsepower increase of almost 5 percent for an installed weight increase of 7 pounds compared to the CC340. The company further noted that it expects “the new engine will be better able to tolerate Autogas and the next generation of aviation fuels than similar higher compression ratio engines.” CubCrafters reports that the CC363i F/P is currently in the final phases of flight testing and it hopes to begin shipping the model to customers as soon as early October. The CC363i F/P will be offered exclusively on experimental/amateur-built Carbon Cubs including the EX-2, EX-3, FX-2 and FX-3 models. The company noted that the original Light Sport Carbon Cub will continue to be powered by the ASTM-certified CC340 engine.
