FAA Chimes In On Ethanol In Fuel
  • The FAA has issued a Special Airworthiness Information Bulletin (SAIB) warning about the significant hazards of using automotive fuels containing alcohol (ethanol) in STC'd aircraft engines.
  • Ethanol is toxic to airplane engines, increasing the risk of vapor lock, introducing water into the fuel system, corroding rubber seals, and reducing available power.
  • If alcohol-free mogas is unavailable, the FAA recommends switching back to 100LL, and the SAIB includes a simple test to detect alcohol in fuel if there's any doubt.
The FAA has issued a special airworthiness information bulletin (SAIB) explaining the hazards posed to aircraft operation with automotive fuels that contain alcohol. EAA and other aviation groups have been warning about the increased use of ethanol in fuels. The alcohol is a substitute for chemical oxygenates MTBE and ETBE that have been linked to environmental concerns. But while ethanol may be safer for the environment, its toxic to airplane engines and the FAA says that if you cant find alcohol-free mogas for your STCd aircraft engine, youll have to switch back to 100LL. Alcohol increases the risk of vapor lock and can also introduce water into the fuel system as it cools at higher altitudes. Its also corrosive to rubber seals used in aircraft fuel systems and reduces the amount of power available from the fuel. Although oil companies are required to prominently label their fuels that contain alcohol, if theres any doubt about its presence, the SAIB includes a simple test that anyone can perform to determine if there is alcohol in fuel.
