Firefighting Fleet Faces Economic Challenges
  • The escalating wildfire season, especially in Southern California, highlights a critical safety concern with aging firefighting aircraft experiencing failures and accidents.
  • The "Strategic Aerial Firefighting Excellence" (SAFE) initiative proposes a 10-year plan to replace the heavy air-tanker fleet and advocates for better structural monitoring of existing aircraft in the interim.
  • To facilitate investment in newer, safer aircraft, the SAFE initiative calls for a two- to three-fold increase in contractor hourly rates, as current rates make modern aircraft acquisitions financially unfeasible due to extended break-even periods.
With summer fast approaching, so is wildfire season, which (along with record-breaking heat) is already blooming in southern California. The pilots who fly firefighting aircraft are well-aware of the accidents noted recently by the NTSB in which aging aircraft failed under the stress, and the industry has come up with its own “White Paper” to address the problems of how to fly safely. Called the SAFE initiative, for “Strategic Aerial Firefighting Excellence,” the plan calls for replacing the current heavy air-tanker fleet, but says that could take 10 years. Meanwhile, the initiative calls for better monitoring of aircraft structures and suggests that contractors will need a two- to three-fold increase in hourly rates to cover investments in new aircraft. According to the report, the current heavy air-tanker rate is approximately $4,000 per flying hour. At this rate for the current type of 1950s aircraft, it is possible to break even on the original air-tanker investment within three years. However, if the contractor was required to acquire an ex-USN S-3 aircraft the break-even point goes to 14.1 years. For a newer type C-130E or P-3C turboprop aircraft, the break-even point goes way beyond 20 years.
