It may be tough to think about icing in the middle of July, but that’s their job at the NTSB, and on Monday the safety board asked the FAA to do more to prevent icing incidents in turboprop airplanes. The NTSB wants all operators of Saab SF340-series airplanes to install an icing-detection system and to instruct pilots to maintain a minimum operating airspeed if icing is encountered or expected. Crews should exit icing conditions as soon as performance degradations prevent the airplane from maintaining that airspeed. Further, the board would like the FAA to require operators of turboprops to instruct pilots, except during intermittent periods of high workload, to disengage the autopilot and fly the airplane manually when operating in icing conditions. More research needs to be done, too. The FAA should convene a panel of specialists in airplane design, aviation operations and human factors, including folks from NASA, to determine if it would be feasible to require the installation of low-airspeed alert systems in airplanes operating under Parts 121 and 135.
NTSB Wants Tougher Icing Rules For Turboprops
- The NTSB urged the FAA to implement new measures to prevent icing incidents in turboprop airplanes.
- For Saab SF340-series airplanes, specific recommendations include installing an icing-detection system and instructing pilots to maintain a minimum operating airspeed in icing conditions.
- The NTSB also asked the FAA to require turboprop pilots to disengage autopilots and fly manually in icing (except during high workload), and to research the feasibility of low-airspeed alert systems for commercial airplanes.
