Approach Light Secrets
  • Approach Lighting Systems (ALS) are crucial for transitioning from instrument to visual flight, providing essential orientation, guidance, and a visual means to estimate flight visibility.
  • The ALSF-2 is the most common and comprehensive ALS in the U.S., featuring sequenced flashing lights, a 1000-foot decision bar, and red side-row lights, but numerous other specialized variations exist, such as ALSF-1, MALSR, and ODALS.
  • Pilots must understand the specific ALS expected for their approach, as well as how to utilize pilot-controlled lighting or request adjustments from ATC, to enhance safety and effectiveness during low-visibility operations.
As much as we drill instrument students on any of the 10 items from FAR 91.175 (c) you must see to go below DA/MDA, in the real world if we see anything that might be part of the runway, we land on it. Its nearly certain that youll first see the approach lighting system (ALS), allowing you to descend to 100 feet AGL and search for something resembling a runway.
But the ALS deserves more respect than just a bunch of lights short of the threshold. It bridges the gap between instrument flight and visual flight.
An ALS performs three essential functions: orientation, measurement and guidance. Know your lights and the ALS will better fill that need.
Lights for Landing
Anyone who has popped out of low clouds knows the runway isnt always centered in the windscreen or even at your roll or pitch angle. ALSs all have some combination of lights, sometimes flashing, to get your attention and offer some direction. Even without knowing exactly what lights to expect, you can get some orientation and guidance-follow these lights to the pavement.
Measurement might take a bit more study. FAR 91.175 says in two places that it doesnt matter what you can see. If you dont also have the required flight visibility, you cant go below DA/MDA. By knowing which ALS to expect, you get a visual yardstick of that flight visibility. (Note that in Canada and some other countries, the ceiling is controlling, not the visibility as in the U.S.)
Also missing in this discussion is the CFI favorite about not descending lower than 100 feet above touchdown-zone elevation by the approach lights alone unless you also see the red side-row lights or terminating bars. Tell the voice of that CFI in your head to stuff it on this one. The extra descent to 100 feetv can be helpful, but unless youre CAT-II or better qualified, the red light part is pointless. The system with all the bells and whistles most common in the U.S. is the ALSF-2. Initially leading you from oblivion to the runway is a column of flashing lights extending from the run- way center line. Each flashing light is in the middle of a narrow row of five white lights parallel to the threshold. There are typically 14 of these rows with the flashing light in the center. These rows of five white lights continue to the threshold, but the flashing lights are removed in the last 1000 feet.
The flashes fire in sequence so it appears as a ball of light zipping down the ALS centerline, towards the runway, twice a second. These are the sequenced flashing lights (SFL), sometimes called the rabbit. Their purpose is to help you acquire the ALS as a whole and orient you to the runway as it comes out of the gloom. But if they distract you, put on your best Elmer Fudd voice and ask Tower to Kill da wabbit. Theres a lot more lighting in that last 1000 feet than just the rows of five white lights. The SFLs stop at a white bar 1000 feet from the threshold thats 100feet wide-visually about three times as wide as the other rows so far. This isoften called the decision or roll bar and it both identifies where the last 1000 feet of the ALS starts, and provides some roll information for the pilot to visually keep the wings level in the transition to visual. At 500 feet before the threshold, theres a mini roll bar of just three extra lights on either side of white center row. This barrette is mainly for Cat-II or lower approaches.
Two columns of red, three-bulb barrettes connect the far ends of the roll bar with the green threshold lights of the runway. These essentially make a runway-shaped box in the 1000 feet before the runway. Only the glideslope or VASI/PAPI give you descent angle guidance, but the shape of this box also helps. These are the red side-lights mentioned in the FARs, and theyre red to remind you this isnt runway youre looking at. Its lighting before the green threshold bar. Some runways have these side-lights continue past the threshold, recessed into the runway itself, but those in-runway ones are white.
Overall, this bright road 2400 feet up to the threshold gives the pilot a visual indication of crab angle and helps prepare for the landing. The choice of 24 rows of lights 100 feet apart is no coincidence since most Cat-I ILS approaches require 2400 RVR or 1⁄2 mile visibility. Approaches with slopes of less than 2.75 degrees get an extra six bars to reach 3000 feet.
Put these pieces together and its clear that they orient and guide, but using them for measurement is interesting. On a standard three degree ILS at 200 feet above TDZE, youre 3816 feet from touchdown. That touchdown zone should be 1000 feet down the runway, so youre essentially 2800 feet from the threshold. If you can see all 24 bars when you reach DA, you have just over 1⁄2 mile of vis. Land.
If you can only see to the roll bar at this point, you have 1800 feet of visibility-less than 1⁄2 mile, which may be enough on some approaches but is typically cause for a missed approach. Note that its the furthest lights you see that tell you the visibility.
Ten More Types?
Yup, all that on one ALS and there are10 more to go. Relax. Seven of em are variations on the ALSF-2 you already know. Three more are of the less common, but similar, ALSF-1.
All this light isnt necessary all the time. So airports with ALSF-2s can cut the electric bill. Kill the red side-row lights, the 500-foot barrette, and the first 1000 feet of white centerline lights and you get something thats 1400 feet long with only white lights. The sequenced flashers still run, but for the first 1000 feet theyre all by themselves, giving them a new name: Runway Alignment Indicator Light, or RAIL. This reduced configuration of RAILs and the rows of white lights only employ every other row, so theyre 200 feet apart.
The ALSF-2 is Approach Lighting System with Flashers, version 2 (or for Cat-2 depending on who you ask). The 1400-foot, truncated version is the Simplified, Short, Approach Lighting with RAIL, or SSALR.
Most ALSF-2 systems have five intensity levels, or steps in ATC vernacular. Cat-I airports only need the first three. This means their lights can only reach medium intensity at full brightness, so when they truncate its not an SSALR, its a MALSR. The M is for medium.
Some runway/approach combinations dont need more than 1400 feet of lights, or physically have no room for them. Four systems are essentially permanently truncated ALSF-2s. The 1400-foot setup with five intensities but no strobes is SSALS. Medium intensity makes it a MALS. Put back in a short line of three strobes up to the roll bar and it becomes either a SSALF or a MALSF. The SF indicates sequenced flashing lights.
ALSF-1 is less common by far in the U.S., and is the same as the ALSF-2 up to the last 1000 feet. The ALSF-1 loses the red side-row bars and puts a wing-shaped pattern of red lights in the last 200 feet to the threshold. These are the terminating bars in 91.175. Now you know something those just parroting the regs dont: you might see red side-row lights (ALSF-2) or red terminating bars (ALSF-1), but never both.
Oddly the ALSF-1 never gets simplified. But it can be shortened. It becomes 1500 feet long and called the SALS. Some keep a few flashers more and are the SALSF. Note the SALS and SALSF versus the SSALS and SSALF; the double S means the parent system was an ALSF-2.
If your approach is an ILS or LPV with minimum visibility less than -mile, then it must have an ALSF-2 or -1, a SSALR or MALSR. Interestingly, for higher visibility minimums an ALS is only recommended by TERPS, not required. So dont assume there will be any ALS for those approaches. This is a good reason to know what ALS to expect … or what not to expect.
The 11th and last is the Omni-Directional ALS, or ODALS, which gets the Monty Python And now for something completely different award. Part of the ODALS is Runway End Identifier Lights (REIL) youll see on many runways, even with other ALSs. REIL are two, omni-directional flashers on either side of the threshold. Add a 1500-foot RAIL leading to the threshold but with no other solid-burning lights and you get an ODALS.
You dont see a lot of these systems, which is another reason to check which ALS youre looking for as part of your approach briefing. Suddenly seeing an ODALS when you were expecting a familiar MALSF might introduce doubt about whether youre even looking at a runway at all-and thats not something you want when mucking about at MDA in low visibility.
Asking for More, or Less
Briefing the approach lights has one additional benefit: It reminds you to make sure theyre set the way you want. With an uncontrolled airport and pilot-controlled lighting, its almost always a good idea to reset the 15-minute timer for lights with seven mic clicks passing the FAF. You can often turn them down if needed later on. See AIM table 2-1-1 for the secret decoder ring of mic clicks.
At towered airports, dont be shy about asking them to turn up the approach lights if youre thinking the ceilings are tight. If its an ALSF-2 or has SS in the name, theres the fifth setting for brightness thats not automatically turned up as it tends to overheat the bulbs. But most of all, show the ALS the respect it deserves. Chances are youll be happy to see it after a long day in the clag.
This article originally appeared in the December 2012 issue of IFR Magazine.
