  • The preliminary accident reports for December 2017 detail various general aviation incidents, frequently involving mechanical failures such as engine power loss, landing gear malfunctions, or onboard fires.
  • Many accidents resulted in forced landings, runway excursions, or impacts with terrain/structures, often leading to substantial aircraft damage and post-impact fires.
  • Several incidents highlight challenges with pilot decision-making and situational awareness, including issues with pilot-controlled lighting systems or navigating adverse conditions.
AVweb’s General Aviation Accident Bulletin is taken from the pages of our sister publication, Aviation Safety magazine and is published twice a month. All the reports listed here are preliminary and include only initial factual findings about crashes. You can learn more about the final probable cause in the NTSB’s web site at www.ntsb.gov. Final reports appear about a year after the accident, although some take longer. Find out more about Aviation Safety at www.aviationsafetymagazine.com.
December 2, 2017, Plato Center, Ill.
Pulsar 912XP Experimental
The pilot reported attempting to activate the airport’s pilot-controlled lighting (PCL) system, but was unsuccessful. He continued toward the airport and, while maneuvering for a landing, he lost sight of the airport. The pilot continued to descend, however, and the airplane sustained substantial damage when it impacted a fence adjacent to the runway at around 1650 Central time. The private airport’s owner reported the PCL does not receive signals from the southeast, due to obstructions. The accident airplane was approaching from the southeast.
December 3, 2017, Thomasville, Ga.
Piper PA-34-200T Seneca II
At about 1520 Eastern time, the airplane was substantially damaged while landing. The commercial pilot and three passengers were not injured. Visual conditions prevailed.
After an uneventful flight, the pilot extended the landing gear but the left main gear did not indicate down and locked. The pilot cycled the landing gear three times, and then utilized the manual landing gear extension procedure, with no changes. Aerial observation of the landing gear by airport personnel indicated all three landing gear appeared to be down. On touching down, the left main gear collapsed, the airplane turned 90 degrees to the left and came to a stop on the runway. Examination revealed the left main landing gear was partially extended and inside the gear well. Structural damage to the left wing was confirmed.
December 4, 2017, Rockford, Ill.
Beech Model C90 King Air
The airplane impacted terrain short of the runway at about 1802 Central time. The private pilot and one passenger sustained serious injuries while two passengers sustained minor injuries. The airplane was substantially damaged. Visual conditions prevailed.
The flight requested a local IFR clearance as it neared the destination and the pilot was cleared for a visual approach to Runway 19. As the airplane approached the airport, the pilot requested the Runway 25 lights be turned on and the airplane was subsequently cleared to land on Runway 25. The airplane impacted terrain before the Runway 25 threshold. At 1754, recorded weather at the airport included winds from 190 degrees at 18 knots, gusting to 25.
December 4, 2017, Rio Oso, Calif.
Beechcraft Model A36 Bonanza
At about 0720 Pacific time, the airplane made an emergency landing to an open field after the solo airline transport pilot noted an onboard fire. The pilot received minor injuries; the airplane sustained substantial damage. Visual conditions prevailed.
The pilot later stated he had started a descent to his destination when he saw a flickering light underneath the instrument panel. Realizing it was a fire, he reduced power and made an intentional gear-up forced landing to a field. The airplane landed in a plowed field and came to rest about 250 feet from its initial touchdown point after rotating 150 degrees to the left. After the pilot exited the airplane, it burst into flames.
December 5, 2017, Brewton, Ala.
Piper PA-28-180 Cherokee 180
The airplane was substantially damaged during a forced landing at about 1400 Central time. The private pilot and passenger were not injured. Visual conditions prevailed.
While en route on an IFR flight plan, ATC cleared the flight to descend from 8000 feet msl to 4000. Subsequently, the engine experienced a total loss of power, and the pilot notified ATC he was diverting. Due to a strong headwind, the airplane was not able to glide to the nearest runway, so the pilot attempted to land in a field. During the landing approach, the airplane collided with tree tops and landed hard. During the roll-out, the airplane contacted a fence post, which damaged the right wing.
Examination revealed damage to the landing gear, fuselage, firewall and right wing leading edge. The left-wing fuel tank, which was undamaged, contained approximately 20 ounces of fuel. The right-wing fuel tank was breached and leaking but was approximately half-full. The fuel selector valve was positioned on the left fuel tank.
December 5, 2017, Glendale, Ariz.
At about 1835 Mountain time, the airplane was substantially damaged during a runway excursion after landing. The flight instructor and a commercial pilot were not injured. Visual conditions prevailed.
Both pilots reported that the left wing dipped during landing roll. Despite their control inputs, the airplane veered to the left side of the runway, collided with a runway sign and came to a stop in a grassy area. The left main landing gear had collapsed during the landing sequence.
December 6, 2017, Chesterfield, Mo.
Beech B36TC Turbocharged Bonanza
The airplane impacted a gas station pump canopy and parking lot at 1454 Central time, following a reported loss of engine power while on a visual approach. The solo private pilot sustained fatal injuries; the airplane was destroyed by post-impact fire. Visual conditions prevailed; the flight was conducted on an IFR flight plan.
According to preliminary information, the airplane was on a left-traffic visual approach when the pilot reported losing power. The local controller immediately cleared the pilot to land but he responded that he may not be able to make it to the airport. No further communications were received from the pilot. Witnesses observed the airplane at a low altitude with no engine noise. Shortly thereafter, the airplane impacted the gas station and a post-impact fire ensued. Witnesses attempted to suppress the fire with available fire extinguishers but were unsuccessful due to the intense heat and smoke.
December 7, 2017, St. Croix, V.I.
Beech 58 Baron
At about 2100 Atlantic time, the airplane was destroyed after it impacted terrain while attempting to return to the airport shortly after takeoff. The private pilot and four passengers were fatally injured. Visual conditions prevailed.
Shortly after takeoff, the pilot reported to ATC, “the engines are not running right,” and requested to return to the airport. The controller instructed the pilot to fly north and cleared the airplane to land on Runway 10. There were no further communications with the pilot. The airplane came to rest on flat terrain, about 380 feet from the Runway 10 threshold and about 60 feet right of the extended runway centerline. The airplane was destroyed by impact forces and consumed by fire. Examination revealed a hole in the top forward portion of the left engine crankcase and connecting rods 4, 5, and 6 were broken. The left engine’s propeller blades appeared to be in the feathered position.
This article originally appeared in the March 2018 issue of Aviation Safety magazine.
