FAA Acts On Personal Electronic Devices
  • The FAA is expanding passenger use of portable electronic devices (PEDs) throughout all phases of flight, based on a committee's finding that devices not using Wi-Fi or cellular connections pose little interference threat.
  • Despite the expansion, restrictions remain; passengers may be asked to turn off PEDs on about 1% of flights where landing systems could be susceptible to interference.
  • Airlines must submit results of tolerance tests to the FAA for approval to implement the expanded PED use, with some carriers like Delta and JetBlue already seeking early adoption.
  • The new guidance does not affect existing restrictions on cellular telephone use or the approval of Wi-Fi devices, which remains limited to altitudes above 10,000 feet.
The FAA is providing airlines with implementation guidance to expand passenger use of portable electronic devices during all phases of flight, FAA Administrator Michael Huerta said Thursday, but there will be restrictions. The FAA was advised by a committee, which determined that the effects of electronic devices not operating via WiFi or cell tower posed little threat. According to Huerta, landing systems involved in about 1 percent of all flights may not be proven to tolerate interference and in those cases passengers may be asked to turn off their portables. Airlines may now submit the results of tolerance tests to the FAA for approval, and some already have. Internet connections and cellphone calls are another matter.
Delta has submitted paperwork for approval, with a spokesman telling USA Today that all of the carrier’s aircraft had been subjected to the required tolerance tests already. JetBlue, which operates fewer aircraft, is also hoping for a competitively early start. The FAAs decision was influenced by the committees determination that most commercial airplanes can tolerate radio interference from portable electronic devices, Huerta said. The FAA will request that airlines ask passengers to store heavier items during critical phases of flight. Cellular telephone use is not affected by the new rules, so consumers may see no changes there. And use of WiFi devices will remain approved only at altitudes above 10,000 feet.
