More Experimental PMAs Likely
  • The EAA and FAA are collaborating to make advanced, non-certified technology, previously limited to experimental aircraft, more accessible and affordable for certified aircraft owners.
  • This initiative leverages an expanded Supplemental Type Certificate (STC) process and a new, tiered Parts Manufacturing Process (PMA) for low-risk, supplementary items, aiming to lower costs and enhance safety and performance.
  • Following the success of a Dynon primary flight display STC, future approvals are planned for items like the TruTrak autopilot, engine monitors, and fuel flow monitors, expanding the range of available modern technology.
Owners of certified aircraft could soon have affordable access to a wide range of cutting-edge technology now reserved for the amateur built market thanks to an emerging joint effort by EAA and the FAA. FAA officials from Washington, Oklahoma City and Chicago went to Oshkosh last week to discuss ways to expand on the success of a groundbreaking move that granted a supplemental type certificate to EAA that allows those who purchase rights to the STC to install a non-certified Dynon primary flight display in their certified aircraft.
EAA’s VP of Safety and Advocacy Sean Elliot told AVweb in a podcast interview that the FAA, with its new risk-based approach to regulation, is enthusiastic about finding ways to get low-risk non-certified safety- and performance-related equipment on certified aircraft through the Parts Manufacturing Process (PMA). It appears the result will be a “tiered approach” to the PMA process where items that really enhance safety, situational awareness or even performance but can’t interfere with the aircraft’s core systems get an easier and less expensive approval process. “This is really significant,” he said. “It will lower costs. It will bring more safety-enhancing and performance-enhancing products into the cockpit for all general aviation pilots that we in the experimental world have appreciated for some time now.”
Since last year’s announcement at Sun ‘n Fun of the Dynon STC on some Cessna models, more than 100 owners have bought the STC and the list of applicable aircraft has been expanded. The next STC application will be a TruTrak two-axis autopilot that Elliot describes as a “known safety enhancement.” The key to the process is presenting items that supplement the required gear on certified aircraft that don’t interfere with those systems if they fail. So, primary instruments and other essential equipment will be left out of the process but that still leaves a wide range of products that have been developed for the experimental world that could benefit the owners of certified planes. He said engine monitors and fuel flow monitors might be the next targets of the program.
