Continental Counterweight AD Expanded
  • The FAA has expanded an Airworthiness Directive (AD) for certain Continental engines, adding new models and clarifying special flight permit rules.
  • This expansion addresses a manufacturing defect where crankshaft counterweight retaining rings were incorrectly installed, potentially causing weights to detach during flight.
  • Operators of affected engines are required to inspect crankshafts to verify proper installation of these counterweight retaining rings.
  • The updated AD, superseding a previous directive, became effective on March 15, 2023.
The FAA has expanded its AD for certain Continental engines regarding potential manufacturing errors with the engines’ crankshaft counterweights. The original AD has been superseded and several new models added. “Since the FAA issued AD 2023-04-08, the FAA determined that IO-470-A, -C, -F, and -LO; and TSIO-360-F and -FB model engines are also affected by the unsafe condition and should be added to the applicability,” a notice says. “Additionally, the FAA determined that the limitations in the special flight permit paragraph, specifying ‘no metal contamination in the oil filter,’ did not account for trace metal particles that may be found in newer engines due to break-in of the engine.”
Operators of the affected engines have to inspect the cranks to ensure the counterweight retaining rings were installed correctly. There had been several instances where the rings were put in incorrectly and the weights came off during flight. Continental spotted the fault and notified the FAA and its customers in February. The expanded AD took effect Wednesday (March 15).
