All 737NGs Need Nacelle Retrofit
  • The FAA has proposed an Airworthiness Directive (AD) for all 6,000 U.S. Boeing 737NG aircraft (600-900 series) to retrofit their engine nacelles.
  • This AD is a response to past fan blade failure incidents on Southwest aircraft, where nacelle pieces pierced the fuselage, leading to a fatality in one 2018 mishap.
  • Required modifications include stronger inlet spacers, a fan cowl support beam, and a redesigned exhaust nozzle, costing $7,650 per engine, taking 90 hours, and due for completion by July 31, 2028.
The FAA has proposed an AD that will require all 6,000 Boeing 737NG aircraft in service in the U.S. to be retrofitted with beefed-up engine nacelles. The AD was issued after a couple of fan blade failure incidents on Southwest aircraft in which pieces of the nacelle pierced the fuselage of the aircraft. In a 2018 mishap, a woman was killed in the resulting explosive decompression, becoming the only airline fatality for that year. The AD applies to all aircraft in the 600 to 900 series. There are also thousands of 737NGs in service in the rest of the world, and aviation authorities in other countries will likely also require the modifications.
The required changes will apparently vary depending on the aircraft model but include new stronger inlet spacers, a fan cowl support beam and a redesigned exhaust nozzle. The retrofits are expected to cost $7,650 per engine and the work will take about 90 hours. The comment period on the AD ends on Jan. 26 and all aircraft have to be in compliance by July 31, 2028.
