FAA Orders Radio Fix On 787s
Comm radio could switch frequencies without pilot input.
dschwen/Wikimedia/https://creativecommons.org/licenses/by-sa/3.0/
  • The FAA has mandated a software upgrade for 157 U.S. Boeing 787s to address a radio glitch.
  • The glitch causes aircraft radios to randomly switch between active and standby frequencies, potentially leading to missed communications with Air Traffic Control.
  • The solution is a straightforward 90-minute software upload, provided free by Boeing, with most operators likely having already complied.
The FAA has ordered a $127.50 software upgrade for 157 Boeing 787s in the U.S. fleet to fix a potentially problematic glitch with their radios. Apparently, the radios will randomly toggle between active and standby frequencies without pilot input. “The uncommanded frequency changes could result in missed communications between the flight crew and Air Traffic Control,” the agency said in an AD issued more than a month ago.
The fix seems simple enough. It’s a software upload to the airplanes’ tuning control panel followed by a configuration check. It will take about 90 minutes to do and Boeing is providing the software for free. Comments can be made until April 14. Boeing issued a service bulletin on Feb. 25, and it’s likely that most operators have already complied.
