Pilot Continues Flight After Gear Torn Off On Takeoff
  • A Renegade Air Dash-8 carrying 38 people sustained significant landing gear damage after striking a dyke during takeoff from Maban, South Sudan.
  • The crew successfully performed a belly landing at Malakal International Airport after burning fuel, with all 38 passengers and crew evacuated without serious injuries.
A Renegade Air Dash-8 with 38 passengers and crew aboard made a successful belly landing after the gear was mostly torn off when it struck a dyke on takeoff from Maban in South Sudan. With portions of the long gear struts dangling from the nacelles, the aircraft continued to Malakal. The plane went into a holding pattern at Malakal to burn off fuel, and all 38 people were evacuated from the plane when it finished its slide.
Apparently the gear was the only thing damaged in the collision with the dyke so the crew likely reasoned they were better off to try the belly landing at Malakal, which is an international airport with full services. Maban is a gravel strip in a rural area. There were no serious injuries reported.
