Garmin’s Turbine Avionics At NBAA 2018
  • Garmin is showcasing new avionics, including a G5000 retrofit for the Cessna Citation XLS, at the National Business Aircraft Association (NBAA) convention in Orlando.
  • The company is also exhibiting other equipment like the G700TXi, emphasizing advancements for the turbine aircraft market.
  • Garmin's Phil Straub discussed these avionics advancements for the turbine market with Aviation Consumer Editor Larry Anglisano at the convention.
As the National Business Aircraft Association convention opens in Orlando, Florida, Garmin is showing off its G5000 retrofit for the Cessna Citation XLS, plus a variety of other equipment, including the G700TXi. Aviation Consumer Editor Larry Anglisano is at the convention and talked with Garmin’s Phil Straub about the advancement of Garmin avionics for the turbine market.
