Video: Max-Viz EVS600 Flight Evaluation
  • The Astronics Max-Viz Enhanced Vision system displays real-time video of the aircraft's exterior environment using an infrared sensor and a visible light camera.
  • It is available as a factory option for many G1000 aircraft and has STC approval for retrofit on most Cessna singles.
  • The system is being evaluated in a Cirrus by *Aviation Consumer*'s Larry Anglisano.
The Astronics Max-Viz Enhanced Vision system uses an infrared sensor and a visible light camera to display a real-time video image of the environment outside of the aircraft. It’s available as a factory option for many G1000 aircraft, plus it has STC approval for retrofit on most all Cessna singles. Aviation Consumer‘s Larry Anglisano evaluates the system in a Cirrus.
