Piper Adds Hartzell Five-Blade Prop
  • Hartzell's new five-blade carbon-fiber composite propeller is now available for Piper Meridian and M500 turboprops, expanding its availability from Socata TBM and Pilatus PC-12 aircraft.
  • The propeller offers significant performance benefits, including a boosted climb rate, decreased noise and in-flight vibration, and improved cruise performance.
  • Key features include a 15-pound weight reduction, unlimited life certification, superior strength (5-10 times stronger than wood core blades), robust FOD protection, and an optimized design for quicker, smoother descents.
Hartzell’s popular five-blade carbon-fiber composite propeller now is available for Piper’s Meridian and M500 single-engine pressurized turboprops, the companies announced this week. “Hartzell’s new Meridian composite prop boosts climb rate while decreasing noise,” said Hartzell President Joe Brown. The blades are certified for unlimited life and are 5 to 10 times stronger than wood core blades, according to the company. They feature a stainless steel shank, nickel cobalt leading edge and mesh erosion screen for FOD protection. The prop is 15 pounds lighter than the current factory-installed aluminum four-blade propeller.
The propeller, first introduced in 2013, is also available on Socata’s TBM turboprop and the Pilatus PC-12. The prop’s performance is driven by both the aerodynamic design and the high-strength materials, the company says. “Hartzell’s five-blade propellers provide lower in-flight vibration,” according to the company. “Through optimized aerodynamic design, the low-end performance is coupled with improved cruise performance. The larger surface area and blockage effect of five-blade propellers provide quicker descents resulting in smoother touchdowns with less float.”
