Aerox Air Venture Promotion
  • Shaw Aerox will offer a 20% discount on all portable oxygen systems, including an oximeter and carrying pouch, during EAA Air Venture 2017 (July 24-30).
  • The promotion highlights Aerox's compact, lightweight, and customizable portable oxygen systems, ideal for pilots in rental or unequipped aircraft, including the PrO2 emergency series.
  • Shaw Aerox, a long-standing manufacturer since 1981, provides a full line of portable and built-in oxygen systems and is uniquely ISO9001:2008 accredited in the aviation oxygen systems field.
Shaw Aerox(R) Aviation Oxygen Systems to provide a Portable Oxygen System Promotion during EAA Air Venture 2017
Press Release: Air Venture 2017 FOR IMMEDIATE RELEASE
Bonita Springs, FL. & Oshkosh, WI, June 12, 2017 Shaw Aerox(R) Aviation Oxygen Systems will offer a promotion of 20% off list price for all Aerox portable oxygen systems. Included in the price will be one oximeter and one seatback carrying pouch during the EAA Air Venture in Oshkosh, Wisconsin, July 24 – 30, 2017. Shaw Aerox will also be displaying the latest in Oxygen System Technology with several unique products designed by Aerox engineers to improve the flying experience for both pilot and passengers at the Shaw Aerox Aviation Oxygen Systems Booth, Number 2080 in Exhibit Hangar B, Aisle D. Oxygen, essential for human life, is abundant at ground level. As flight levels increase, atmospheric pressure decreases necessitating the requirement for supplemental oxygen. Also, during the Show if you are feeling a bit tired, sluggish or just in need of an energy boost, please visit our booth for a quick oxygen refresher to help you get through the day.
Shaw Aerox Portable Oxygen Systems , which are compact and exceptionally light, can be put together to meet customers’ individual requirements and are ideal for pilots that frequently rent or use aircraft that are not equipped with built in oxygen systems.
The Aerox PrO2 – 2, PrO2-4 and PrO2-6 Personal Emergency Oxygen Systems provide take anywhere convenience and safety at a reasonable cost. Multiple configurations depending on number of pilots and passengers can be provided to suit your needs. The systems are designed to deliver oxygen based on a cabin pressure of 25,000 feet and will flow oxygen at a predetermined rate from 17 to 60 minutes depending on system configuration to allow descent to a safe altitude where you can breathe normally under current conditions.
Simple to use when needed, just pull the mask and don. The motion of pulling the mask pulls a cable to activate the flow of oxygen. The systems come with aluminum DOT-3AL cylinders with no life limits and require a 5 year recertification.
If you can carry a soft drink can, you can carry the Aerox PrO2 Personal Safety System. Shaw Aerox also offers a complete line of FAA-PMA (Parts Manufacturer Approval) cylinder assemblies available as direct replacements for most aircraft.
Page 2
Available in either Kevlar(R) composite fiber wrapped (5 year hydrostatic tested with 15 year service life) or 4130 steel cylinders per DOT 3HT and TC-3HTM (5 year hydrostatic tested with 24 year service life).
Manufactured and cleaned specifically for oxygen service, Aerox cylinders are offered in a number of sizes and capacities depending on the airframe’s original equipment specifications. Complete cylinder and valve assemblies are also available.
Shaw Aerox also offers other emergency system options as well as a full line of portable and built in oxygen systems.
About Aerox(R) Oxygen Systems, Inc. Shaw Aerox(R) Oxygen Systems, Inc. designs and builds innovative, high-duration oxygen systems made specifically for the aviation industry. Since 1981, pilots and passengers around the world have depended on Aerox O2 aviation masks, cannulas, cylinder tanks, portable oxygen and emergency oxygen systems to keep them healthy, alert and safe in the air.
Shaw Aerox has relocated to new facilities, effective June 19, 2017. The Manufacturing Center is now located at: 25190 Bernwood Drive Bonita Springs, FL 34135 and the Engineering Center is at 33 McAlister Farm Road, Suite 201 Portland, ME 04102. Phone Numbers have remained the same: 207 637 2331 and 800 637 6902.
Our ISO9001:2008 Stage 2 audit has been passed and the auditors (CIC Management) have confirmed to the registrar (DAkkS) that Shaw Aerox LLC has an acceptable Quality Management System and has been provided with ISO9001:2008 accreditation. Shaw Aerox is unique in the aviation oxygen systems field as the only manufacturer receiving this distinction.
For more information about any of our products or to learn more about our custom system design capabilities, please visit www.aerox.com, call 1-800-237-6902 or email Aerox@aerox.com ###
Media Contact: Andrew Devlin Director of Operations Shaw Aerox Aviation Oxygen Systems, Inc. 25190 Bernwood Drive Bonita Springs, FL 34135 www.aerox.com adevlin@aerox.com (239) 405-3616 1-800-637-6902
