Garmin Pilot Adds New Flight Planning Tools To Apple Devices
  • Garmin Pilot on Apple mobile devices now integrates comprehensive weight and balance calculations directly into flight plans, accounting for fuel burn and providing visual alerts for exceeding limits.
  • Enhanced aircraft performance tables are included, allowing pilots to calculate climb, cruise, and descent profiles specific to their aircraft.
  • A new "Freehand" flight planning feature enables quick, graphical editing and redrawing of flight paths directly on the moving map.
  • The update also introduces pilot-configurable and interactive checklists, which can be customized by category and phase of flight within the app.
OLATHE, Kan. — Garmin International Inc., a unit of Garmin Ltd. (NASDAQ: GRMN), today announced integrated weight and balance calculations, as well as aircraft performance tables and calculations within the Garmin Pilot app on Apple mobile devices. Also new to Garmin Pilot, Freehand flight planning allows for quick and easy flight plan editing from the moving map page. Pilot-configurable checklists are also integrated within Garmin Pilot, providing pilots the option to create custom checklists that are accessible within the app. These new features and more are available as a free update for existing customers and provide pilots with even more tools to aid in flight planning and in-flight navigation all within a single mobile application.
“We continue to pack more features and incorporate more capabilities into Garmin Pilot to provide our customers with a premier, all-inclusive application,” said Carl Wolf, Garmin vice president of aviation sales and marketing. “Pilots have been requesting an all-in-one app that merges their flight plan with other information pertaining to the flight, such as performance calculations, weight and balance and more. We’re excited to be the first to bring our customers this fully integrated experience so pilots have everything they need – from pre-flight to post-flight – all within Garmin Pilot.”
Integrated weight & balance
Garmin Pilot is the first application that incorporates weight and balance calculations into a flight plan or a saved trip, taking into account fuel burn and more for a comprehensive look at weight and balance characteristics throughout an entire flight. Pilots can take advantage of pre-loaded aircraft types or enter aircraft weight and balance figures manually, noting the arm, moment and station of each point from the Pilot’s Operating Handbook (POH). Figures such as center of gravity (CG) are easily referenced in the application relative to an active flight plan. In the event CG limits entered within the app are exceeded, pilots receive a visual alert. Additionally, customized weight and balance profiles can be shared across multiple Garmin Pilot accounts. For example, pilots that operate a single airplane in a club can easily share the same weight and balance profile across different Garmin Pilot accounts.
Enhanced performance calculation
New performance tables conveniently calculate climb, cruise and decent profiles so pilots can easily reference performance characteristics specific to their aircraft within Garmin Pilot. Pilots are provided with an interactive and graphically-rich interface to input figures that calculate aircraft performance, including variables such as power setting, fuel and distance to climb and cruise. All aircraft performance calculations also take into account pertinent factors such as outside air temperature (OAT) and altitude. Several of the most popular fixed-wing aircraft models among Garmin Pilot users are pre-populated within the app, however, similar to weight and balance data, aircraft performance tables that are Garmin PilotTM adds suite of new tools for pre-flight planning and in-flight operations to Apple mobile devices
Introduces weight & balance, aircraft performance tables, checklists, Freehand flight plan and more manually created may be shared across multiple Garmin Pilot accounts. Additional aircraft types are expected to be added to the aircraft library in upcoming Garmin Pilot releases.
Additional flyGarmin(R) integration
Enhanced flyGarmin integration provides customers with more opportunities to easily customize and save data within the Garmin Pilot app. Pilots now have the option to input and save their own aircraft performance characteristics manually within the flyGarmin website, which can be shared across individualized aircraft profiles with other pilots across different accounts. Customized checklists can also be created within flyGarmin and synced to the Garmin Pilot app on a mobile device.
Freehand
With a single tap pilots can utilize new Freehand flight plan editing, which can be quickly accessed via the radial menu within Garmin Pilot. Freehand allows pilots to easily plan or fly around weather, airspace, terrain or other pertinent features without leaving the moving map. Simply access Freehand by long- pressing over an active flight plan route on the map. By selecting the graphically edit icon within the radial menu, pilots can either tap individual waypoints or utilize Freehand mode to dynamically draw a route, which uses a combination of NavAids, intersections and airports to generate a new flight plan with a simple finger swipe across the map.
Customized Checklists
Checklists can now easily be created and displayed within the Garmin Pilot app. Similar to an aircraft POH, these checklists can be categorized by normal, abnormal and emergency and then sorted even further by phase of flight, such as preflight, before take-off and before landing. Customized checklists are also interactive, allowing pilots to select each individual checklist item. When selected, the checklist item turns green and a green checkmark confirms the step has been completed.
Additional features – Pilots can easily import multiple user-defined waypoints into Garmin Pilot using a CSV file format from a computer.
– Flight plans can now be created online using AOPA’s Flight Planner or SkyVector on a computer and sent to Garmin Pilot on a mobile device.
– Pilots can configure home screen icons to suit their flight planning preferences.
Garmin Pilot 8.5 for Apple mobile devices is available immediately as a free update, providing existing customers access to these latest features. For new customers, Garmin Pilot is available in the Apple App StoreSM as a free download for the first 30 days. After the 30-day trial period, customers may purchase an annual subscription of Garmin Pilot for the U.S. starting at $74.99.
For additional information, visit: www.garmin.com/aviation.
Garmin’s aviation business segment is a leading provider of solutions to OEM, aftermarket, military and government customers. Garmin’s portfolio includes navigation, communication, flight control, hazard avoidance, an expansive suite of ADS-B solutions and other products and services that are known for innovation, reliability, and value. For more information about Garmin’s full line of avionics, go to www.garmin.com/aviation.
