New Five-Wing, Manned VTOL to Launch at EAA Airventure 2014
  • Elytron aircraft are designed to combine the vertical take-off and landing (VTOL) capabilities of helicopters with the speed, efficiency, and safety advantages of fixed-wing aircraft.
  • The innovative design features a unique triple-wing configuration, including proprotors on a central tilt-wing, enabling airspeeds 2-3 times that of helicopters, greater fuel efficiency, and superior glide capabilities.
  • Elytron's solution prioritizes simplicity and safety, significantly reducing complex control parts compared to helicopters and eliminating the need for autorotation in the event of engine failure.
  • Elytron has built a 2-seater demonstrator aircraft and intends to commence flight testing in 2015, with plans for commercial applications such as emergency medical services, search and rescue, and air taxi services.
Jul. 22, 2014 – OSHKOSH, Wis. — For the past 60 years, engineers have tried to combine the advantages of airplanes and helicopters, but currently the Boeing V-22 Osprey is the sole realization to be in production. The Elytron family of aircraft is designed to provide the vertical take-off and landing capability of helicopters combined with the speed and efficiency advantages of fixed wing aircraft. Elytron’s solution provides greater safety, speed, and simplicity of operation over any existing class of vertical take-off aircraft which makes it ideally suited for various uses, such as emergency medical services, search and rescue, air taxi, and oil exploration.
The concept for the Elytron design has evolved over a 10-year period during which Elytron Aircraft LLC experimented with several quarter-scale convertiplanes, as well as full-size airframe modeling, extended flight simulations, and CFD simulations. The popular Verticopter flying-wing design with in-wing propulsion was the most successful of these prototypes but still had aerodynamic limitations. In 2012, Elytron Aircraft LLC invented a new and optimized wing configuration that addressed all of the earlier design shortcomings.
The Elytron design combines three sets of wings: one pair of rotary wings called “proprotors”, mounted on a single tilt-wing in central position, and two pairs of fixed wings. . The plane has superior glide ratios and low stall speeds because of this low wing loading design, and also displays excellent Short Take-off and Landing (STOL) capabilities.
Elytron aircraft will be capable of achieving airspeeds two to three times those of equivalently powered helicopters. The airframe has also been optimized for low drag at the higher airspeeds made possible by its tilt wing. Fixed wings planes are also far more fuel efficient than rotary wing aircraft, reducing operational costs and increasing range. The combination of the speed of a fixed wing plane and the vertical take-off of a helicopter will allow for applications such as air taxi from city center to city center.
The Elytron mechanism for controlling the plane during vertical flight will have far fewer parts than helicopter swash plates. Elytron’s design has no complex hub but instead distributes the parts across the tilt wing making them lighter and easier to inspect and maintain. All of the tilt wing actuators have redundant control. In the case of engine failure, the airframe’s superior glide ratio will eliminate the need for autorotation, which is a requirement in any helicopter.
Elytron has built a 2-seater demonstrator aircraft which serves as a technology showcase. The next step for Elytron is to start commercial applications which include a 7-seater class of aircraft able to support applications, such as emergency medical services.
Elytron invites you to visit their display at EAA AirVenture Oshkosh 2014, Booth I-9 in the EAA Innovation Center on Monday July 28 – Friday August 3, where their 2-seater demo aircraft, assembled as an all carbon composite airframe, will be on display. Elytron intend to commence flight testing in 2015. Further inquiries may be submitted via the company’s website at https://elytron.aero/
