Unique Zenair Blind Rivets Available at Aircraft Spruce
  • Zenith Aircraft Company's unique blind rivets, featuring a dome-shaped head for enhanced strength and improved aerodynamics, are now available through Aircraft Spruce and Specialty.
  • These rivets simplify metal kit aircraft construction due to their ease of pulling, a method pioneered by Chris Heintz in the 1970s as an alternative to bucked solid rivets.
  • The rivets will be prominently used in the "One Week Wonder" aircraft build at AirVenture, inviting public participation in assembling a CH 750 Cruzer.
  • Available in 1/8" and 5/32" diameters with specific shear strengths, the rivets and compatible pneumatic or manual riveters can be purchased from Aircraft Spruce or directly from Zenith.
Mexico, MO – Zenith Aircraft Company is making available their unique blind rivets through Aircraft Spruce and Specialty. Blind (or pulled) rivets are a common type of fastener used in metal kit aircraft construction. They are available in 1/8″ and 5/32″ diameters. What makes the Zenair rivet distinctive is that as the rivet is pulled, the rivet head is drawn into a dome-shaped top which gives the finished rivet a low profile rounded top, enhancing the strength of the rivet while improving airflow over it. The ease with which these rivets can be pulled, or “popped”, saves considerable time and simplifies the entire kit building process. Aeronautical engineer Chris Heintz, designer of the popular Zenith line of kit planes, first started using structural blind rivets for light aircraft construction in the 1970s when he sought an easier alternative to bucked solid rivets, which require additional tooling and skills. “We’ll be using Zenair rivets during the construction of the One Week Wonder at AirVenture this summer,” said Sebastien Heintz, President of Zenith Aircraft. “Volunteer builders begin unpacking a complete kit for a CH 750 Cruzer on opening day and expect to taxi the completed aircraft within a week. We expect several thousand people to stop by the construction area and pull a blind rivet, so they can say they helped build an aircraft.” Aircraft Spruce also carries the Zenair Pneumatic Riveter for $99.85 along with the Zenair Manual Riveter for $49.50, both of which feature the required domed head for pulling and forming the rivets. A package of 100 1/8″ rivets (part number 12-03709) costs $11.65 and have a shear strength of 130 lbs. The 5/32″ rivets (part number 12-03711) are $16.75 with shear strength of 220 lbs. For more information visit AircraftSpruce.com. Zenith kit builders can purchase the same products directly from the Zenith Aircraft Company. See ZenithAir.com. To watch a demonstration of pulling Zenair rivets, EAA has made a short video showing the process: https://bit.ly/1siNAE1.
