2026 Oshkosh Flight Procedures Now In Effect
The FAA notice covers the major arrival, departure and airport restrictions pilots will encounter through July 27.
[Credit: Thierry Weber | Shutterstock]
  • Special FAA flight procedures for EAA AirVenture Oshkosh 2026 are now in effect through noon CDT July 27, covering Wittman Regional Airport and surrounding areas, with the full 32-page FAA notice serving as the official guide.
  • Most VFR traffic will use the Fisk arrival, requiring pilots to obtain ATIS, monitor specific frequencies, maintain standard altitudes (e.g., 1,800 feet MSL at 90 knots), ensure separation, and follow ATC instructions for runway assignments.
  • Wittman Regional Airport has nightly closures (8 p.m. to 7 a.m. for arrivals, 8 p.m. to 6 a.m. for departures) and closes during airshows, with specific requirements for IFR operations, turbine, warbird, and other aircraft types.
  • Pilots are reminded to carry the complete FAA notice, check current NOTAMs and TFRs, plan for potential holding or diversion with adequate fuel, and prioritize safe airspeeds and go-arounds when necessary.
The FAA’s special flight procedures for EAA AirVenture Oshkosh 2026 are now in effect. The 32-page notice applies through noon CDT July 27 and covers operations at Wittman Regional Airport and several surrounding airports. Take a look, below.
A few points below serve only as a quick, high level refresher and are by no means comprehensive, nor are they an official guide. It should go without saying that anyone flying the Oshkosh flight procedures should read and rely on the complete FAA notice, carry it in the aircraft and check current NOTAMs, TFRs and ATIS information.
Arrival Basics
Most VFR traffic will use the Fisk arrival, beginning at a transition point assigned by ATC. Traffic will then proceed toward Ripon and follow the railroad tracks to Fisk. Pilots should obtain the Arrival ATIS on 125.9 no later than 60 miles from Oshkosh. They should then monitor Fisk Approach on 120.7. The standard arrival profile is 90 knots at 1,800 feet MSL, while faster aircraft may use 135 knots at 2,300 feet when needed for safety.
Aircraft should remain at least one-half mile behind similar traffic and avoid overtaking, side-by-side flight or S-turns. At Fisk, controllers assign the runway, route to the airport and tower frequency. Pilots may be asked to fly a short approach or land on a designated runway dot, and the notice repeatedly reminds crews to maintain a safe airspeed and go around when an approach does not look right.
Closures And Planning
Wittman Regional is closed to arrivals each night from 8 p.m. until 7 a.m. and to departures from 8 p.m. until 6 a.m. The airport also closes during airshows, TFRs and certain special activities. Nonscheduled IFR arrivals and some IFR departures require reservations during designated periods, while separate procedures apply to turbine and warbird aircraft, seaplanes, helicopters, ultralights, rotorcraft and approved no-radio vintage aircraft.
Fond du Lac, Appleton and Green Bay are among the recommended alternates when Oshkosh closes, parking fills or the arrival becomes unavailable. Pilots should arrive with enough fuel for holding, a possible go-around and a diversion.
The full FAA Oshkosh flight procedures notice remains the controlling reference for the applicable routes, frequencies, altitudes and contingencies.
Have fun, and fly safe!
Matt Ryan
