General Aviation Accident Bulletin, July 24, 2023
  • Three general aviation accidents occurred in April 2023, including two off-field landings caused by engine failure and one runway overrun.
  • Both engine failure incidents involved sudden power loss and oil obscuring the windshield, with one pilot seriously injured and the other uninjured despite prior awareness of engine issues.
  • A runway overrun incident involved a Cessna 402 on a wet runway, where the pilot reported brake malfunction and ATC noted a late touchdown, leading the aircraft into an engineered materials arresting system (EMAS).
April 8, 2023, Morgan, Utah
Van’s RV-7 Experimental
At about 1937 Mountain time, the airplane was substantially damaged in an off-field landing following engine failure. The solo pilot was not injured. Visual conditions prevailed.
Earlier, an engine condition inspection revealed particles in the oil screen. After consulting a mechanic, the pilot decided to continue flying the airplane and closely monitor the engine. About 15 minutes into a local flight, the pilot noticed a burning odor when he activated the heater, turned back toward the departure airport and then noticed a vibration, followed about a minute later by a “sudden shudder” and then observed oil covering the windshield. The engine subsequently lost power. The pilot had no forward visibility due to the oil ob-structing the windscreen. The airplane landed in a field, flipped over and came to rest inverted.
April 9, 2023, Ft. Lauderdale, Fla.
Cessna 402 Businessliner
The airplane was substantially damaged at about 1613 Eastern time when it entered the engineered materials arresting system (EMAS) after a runway overrun. The airline transport pilot and six passengers were not injured. Visual conditions prevailed for the FAR Part 135 on-demand air taxi flight.
The flight departed Nassau, Bahamas, at about 1450 and flew under VFR to Fort Lauderdale. The pilot later reported he was attempting to land on Runway 10R, which was 8000 feet long, and that the airplane touched down on the wet runway about midfield. The left brake “did not work” and he did not want to apply too much right brake and lose directional control. The airplane subsequently traveled off the end of the runway and into the EMAS, where it came to rest upright.
According to ATC, the airplane approached Runway 10R and flew right traffic at about 140 knots groundspeed. A controller reported the airplane touched down on the wet runway with approximately 1600 feet remaining.
April 14, 2023, Crestview, Fla.
Cessna 177RG Cardinal RG
At about 1440 Eastern time, the airplane was substantially damaged during an off-field landing following engine failure. The solo pilot was seriously injured. Visual conditions prevailed.
The pilot was conducting practice approaches. Shortly after receiving an approach clearance, he heard a “boom” from the propeller hub, which immediately began to shudder violently and oscillate in a semi-oval pattern. Engine oil coated the windshield and impaired forward visibility. The pilot opted to leave the landing gear retracted. The airplane and touched down in an area of cut trees, and then slid approximately 100 feet into a marsh.
This article originally appeared in the July 2023 issue of Aviation Safety magazine.
