John Deakin’s Engine-Related Columns
  • This page compiles John Deakin's "Pelican's Perch" columns from AVweb, offering insights from his extensive experience with piston engines.
  • The articles cover a wide range of piston engine topics, including fuel management, turbocharger operation, propeller mechanics, mixture control, and challenging common myths about engine abuse and detonation.
  • Deakin provides practical advice on optimal engine operation across all flight phases—climb, cruise, and descent—based on his detailed study and testing.
AVweb’s John Deakin has been studying, testing, and teaching about piston engines for a long time. This list is a collection of all his Pelican’s Perch columns related to piston engines.
Pelican’s Perch #7:
Run That Fuel Tank Dry!
Pelican’s Perch #8:
Go Ahead, Abuse Your Engine!
Pelican’s Perch #15:
Manifold Pressure Sucks!
Pelican’s Perch #16:
Those Marvelous Props
Pelican’s Perch #18:
Mixture Magic
Pelican’s Perch #19:
Putting It All Together
Pelican’s Perch #31:
Those Fire-Breathing Turbos (Part 1)
Pelican’s Perch #32:
Those Fire-Breathing Turbos (Part 2)
Pelican’s Perch #33:
Those Fire-Breathing Turbos (Part 3)
Pelican’s Perch #34:
Those Fire-Breathing Turbos (Part 4)
Pelican’s Perch #35:
Those Fire-Breathing Turbos (Part 5)
Pelican’s Perch #36:
Those Fire-Breathing Turbos (Part 6 – and FINAL!)
Pelican’s Perch #43:
Detonation Myths
Pelican’s Perch #46:
“But My Mechanic Says …”
Pelican’s Perch #55:
Lead in the Hogwash
Pelican’s Perch #57:
The Whyalla Report – Junk Science?
Pelican’s Perch #58:
FLYING’s Report on Whyalla
Pelican’s Perch #63:
Where Should I Run My Engine? (Part 1)
Pelican’s Perch #64:
Where Should I Run My Engine? (Part 2 — The Climb)
Pelican’s Perch #65:
Where Should I Run My Engine? (Part 3 — Cruise)
Pelican’s Perch #66:
Where Should I Run My Engine? (Part 4 — Descent)
