Kennon Insulated Engine & Prop Covers: The Key to Effective Pre-Heating
  • The Kennon Insulated Engine Cover is designed to retain engine heat during pre-heating and eliminate the need for re-preheating for up to six hours after shutdown.
  • It features a unique construction using high-tech Dacron fiber insulation laminated between two layers of waterproof nylon, preventing fiber shifting and maintaining insulation quality.
  • The covers are compatible with any preheat system and are available for various aircraft types, with prices starting from $265 for small singles.
The Kennon Insulated Engine Cover is designed to help retain as much existing heat as possible and to distribute heat uniformly over the entire engine during any pre-heating operation. It is also used for up to six hours after the engine has been shut down to eliminate the need to pre-heat again. They may be used with any preheat system.
Kennon’s Engine Cover is constructed from high-tech Dacron fiber insulation laminated between two layers of waterproof domestic nylon oxford cloth. Kennon’s exclusive laminated blanket construction prevents the fiber from shifting and eliminates the necessity of quilting the blanket which is desirable since quilting destroys the loft and therefore decreases the insulating quality of the blanket.
For an in-depth discussion of engine pre-heating, read AVweb’s interview on the subject with Kennon’s Ron Kensey.
Small singles $265, larger singles $295, most twins $630 (some twins more – please call).
