Specs for the Rockwell STS
  • The Space Shuttle exhibits extreme performance, featuring zero takeoff distance, an orbital velocity of 27,875 kph (17,321 mph), and a remarkable climb rate of 132,000 fpm to reach orbit altitudes between 185 to 643 kilometers.
  • Its operational profile includes a massive liftoff weight of 2,041,166 kg (4.5 million pounds) which drastically reduces to 104,326 kg (230,000 pounds) at touchdown, with a maximum cargo capacity of 28,803 kg (63,500 pounds) to orbit.
  • The ascent sequence involves Solid Rocket Booster separation at 2 minutes and External Tank separation at 8.6 minutes, while atmospheric flight is characterized by a typical landing ground roll of 10,000 ft and a never exceed speed (VNE) of 333 kt.
PERFORMANCE
Takeoff distance, ground roll: 0 ft
Takeoff distance over 50-ft obstacle: 0 ft
Maximum demonstrated crosswind component: 15 kt
Rate of climb (typical ascent profile at 130,000 ft): 132,000 fpm
Orbit Altitude: 185 to 643 kilometers (115 to 400 statute miles)
Orbit Velocity: 27,875 kph (17,321 mph)
Lift-to-drag (glide) ratio —
Hypersonic: 1.05
Subsonic: 5.1
Landing distance, ground roll (typical): 10,000 ft
Landing distance, ground roll (minimum): 7,000 ft
LIMITING AND RECOMMENDED AIRSPEEDS
(ATMOSPHERIC)
VLD (best glide speed), sea level: 185 kt (heavy)
VA (design maneuvering speed): 185 kt (approx)
VLE (max gear extended): 312 kt
VLO (max gear operating): 312 kt
VNE (never exceed): 333 kt
VSO (stall, landing configuration): 150 kt
DETAILED SPECIFICATIONS
Length —
Space Shuttle System: 56.14 meters (184.2 feet)
Orbiter: 37.23 meters (122.17 feet)
Height of Orbiter on runway: 17.27 meters (56.67 feet)
Wingspan: 23.79 meters (78.06 feet)
Weight —
At Liftoff: 2,041,166 kilograms (4.5 million pounds)
At Touchdown: 104,326 kilograms (230,000 pounds)
(varies depending on payloads and on-board consumables)
Maximum cargo to orbit: 28,803 kilograms (63,500 pounds)
CLIMB PARAMETERS
Solid Rocket Booster Separation: 2 minutes after launch
External Tank Separation: 8.6 minutes after launch
Altitude: 109.26 kilometers (59 nautical miles)
Velocity: 28,067 kph (17,440 mph)
Return to Main Rockwell STS Page
