Zenair Introduces CH-750 Cruzer
  • The Zenair 750 Cruzer is a new aircraft design optimized for comfortable cross-country and conventional airport operations, a shift from its predecessors' short-field focus.
  • It features a new wing and tail, wheel pants, a standard 130-hp UL350is engine, and a useful load of 540 pounds.
  • The metal airframe is designed for straightforward construction, with Zenair estimating assembly in 400 hours using basic skills and tools.
One of the few new designs introduced at Sun ‘n Fun likely looks slightly familiar, but Zenair’s new 750 Cruzer has a different mission from its well-known predecessors. Rather than emphasize the short-field capabilities of its ancestors, the CH-701 and CH-750, the 750 Cruzer is designed for comfortable conventional field and cross-country operations. “We’ve optimized the new design for cruise and typical (airport) operations, while retaining the popular cabin features of the STOL CH-750,” Zenair spokesman Sebastien Heintz said. “We’ve retained some of the most popular features of the STOL CH-750, while optimizing the new design for cross-country flying,” As if to punctuate that point, Heintz flew the Cruzer 1,000 miles from the factory in Mexico, Mo., to Sun ‘n Fun.
It has a new wing and tail (fin and rudder instead of moveable vertical stab) and even sports wheel pants. Up front is a 130-hp UL350is fuel injected engine. Empty weight is 780 pounds so the useful load is 540 pounds. Although the UL engine is standard, the firewall is borrowed from the CH-650 and CH-750 so it will take virtually any popular engine in the 100-hp range. Zenair says anyone with basic skills and hand tools can put the metal airframe together in 400 hours.
Click here for a video look at the CH-750 at Sun ‘n Fun.
