Homebuilt Fatal Accidents Down 28 Percent
  • Fatal accidents involving amateur-built aircraft decreased by 28% in the FAA's most recent 12-month period, dropping from 39 to 28.
  • Fatal events in the broader experimental category also saw a nearly 30% reduction, contributing to a historic low in the total number of accidents for experimental aircraft.
  • Over the past 15 years, the total number of homebuilt fatal accidents has been nearly halved, indicating a sustained positive trend in aviation safety.
The Experimental Aviation Association (EAA) says the number of amateur-built fatal accidents dropped by 28 percent compared to the previous year.
During the FAA’s 12-month period, which concluded Sept. 30, 2023, there were 28 fatal accidents in amateur-built aircraft—down from 39 fatal accidents in the previous year. Additionally, experimental category aircraft saw a nearly 30 percent decrease in fatal events compared to the prior 12-month period.
While the accident rate per flight hour data will not be available until the FAA releases its general aviation survey next year, EAA says the total number of accidents over the past year in experimental aircraft reached a historic low.
“The activity data is necessary to paint the full picture, but the initial indications are very positive indeed,” said Sean Elliott, EAA’s vice president of advocacy and safety. “It shows a continuing trend toward safer operations, even as total hours flown increase. It reminds us that safety is an ongoing journey that always needs the highest attention of our flying community.”
According to the association, “the homebuilt fatal accident total has been cut by nearly half over the past 15 years, from 598 in the period from 1998-2007, to 338 from 2014-2023.”
Amelia Walsh
