BendixKing Intros Flight Deck For Experimentals
  • BendixKing introduced the XVue Touch, an integrated flight deck for experimental aircraft priced at $5499, with a certified version (AML-STC) for over 350 aircraft also available at $12,590.
  • The system features a 10.1-inch high-resolution (near 4K graphics) touch display with split-screen capability, SmartView synthetic vision, and comprehensive PFD/MFD functions including moving maps and ADS-B weather/traffic.
  • Leveraging technology from F-16 avionics, the XVue Touch includes a separate control panel, built-in Wi-Fi, USB-C, and is convection-cooled with no moving parts, offering compatibility with major navigators.
With little fanfare, at Sun ‘n Fun 2018 BendixKing was showing its new XVue Touch integrated flight deck for experimental aircraft. Priced at $5499, the XVue Touch system has a high-resolution (near 4K graphics) 10.1-inch WUXGA color display with split-screen capability. The coated glass used on the display is anti-scratch, anti-glare and anti-smudge. The tech trickles down, in part, from hardware used in the F-16 fighter aircraft’s avionics, according to BendixKing.
Able to display a full-screen PFD, an MFD and a combination of both, the 7.59-pound XVue Touch display has Honeywell’s SmartView synthetic vision and a wide 80-degree viewing angle. The MFD has a moving map, VFR and IFR charting and can display ADS-B weather and traffic data. The system has a shallow feature set, as all critical functions can be accessed in two touches or less.
The XVue uses a 1.48 by 6.25 by 3.67-inch control panel that houses four rotary knobs for commonly used functions like setting the heading bug (the system will have third-party autopilot compatibility), setting the baro, course select and altitude bug. It also has built-in Wi-Fi (for database and software loads) and a USB-C port. The touch display has no bezel knobs or buttons. Flight data is derived from a solid-state ADAHRS, of course, plus a magnetometer and OAT sensor.
BendixKing says the XVue Touch is compatible with the company’s KSN770 navigator, Garmin’s GTN750/650 navigators, plus Avidyne’s IFD-series navigators. There are no moving parts—not even an internal cooling fan—because the display is convection cooled.
The XVue Touch is available for purchase now, via BendixKing’s distributor Aviall (www.aviall.com).
Looking to install the XVue in your certified aircraft? You can’t, just yet, since it isn’t certified. But, BendixKing told AVweb that a certified version—with an AML-STC (approved model list via supplemental type certificate)—will be available at the end of June 2018. It will cover over 350 aircraft and carry a higher price tag of $12,590.
For more, visit www.bendixking.com.
