Sandel Avionics SN3308 Electronic HSI Supplement:<br>Wire List Matrix for Mike Busch’s SN3308 Installation
  • This document functions as a detailed wiring guide, outlining specific pin connections for various electrical signals across multiple avionics connectors.
  • It categorizes signals by function, including power, ground, GPS data, HSI/NAV controls, ADF, marker beacon, autopilot inputs, and serial data.
  • The table specifies interconnections for a diverse range of avionic components, identified by connectors such as SN3308, GX50 GPS, KNS-80 NAV#1, and KG-102A GYRO.
SIGNALS
CONNECTORS
SN3308
P1
SN3308
P2
SN3308
P3
GX50
GPS
RS08
RELAY
NSD-360
PLUG
KNS-80
NAV#1
DATA
LDR
KR-87
ADF
KMA-24
MBR
KG-102A
GYRO
FLUX
GATE
DIMMER HI26M
DIMMER LO
28 VDC CBKR11111-1214
28 VDC CBKR20
GROUND316220115Y
GROUND2234c-j-n
KEEP ALIVE2
JUMPER7-25
JUMPER3-4
EXT SW #122
EXT SW #214
GPS 1 RELAY37
SIGNAL GND4
GPS: APCH3133
GPS: MSG1116
GPS: HOLD3234
GPS: WPT2917
GPS: ACTV1215
GPS: ARM SW23
GPS: HOLD SW226
GPS GS +30
GPS GS –31
GPS GS FLG+28
GPS GS FLG –29
GPS TO1216
GPS FROM1110
GPS FLG+108
GPS FLG-2914
GPS DEV+1312
GPS DEV-1418
HSI GS+1627F
HSI GS-3428E
HSI GS FLG+15302
HSI GS FLG-3329E
SHIELD
HSI TO1735
HSI FROM3529
HSI FLAG+1827
HSI FLAG-3633
HSI DEV+1931
HSI DEV-3737
HSI OBS C (KNS80)16H
OBS D3224B
OBS E2823J
OBS F1426D
OBS G25K
OBS H131510
NAV TO17337
NAV FROM11348
NAV FLG+9315
NAV FLG-15326
NAV DEV+13183
NAV DEV-19175
NAV1 ILS EN279
NAV1 VIDEO29A
NAV2 ILS EN8
NAV2 VIDEO10
FLUX LOtE
MOTOR A30P
MOTOR C11L
FLUX EXIT7ZH
FLUX X25B
FLUX Y6A
FLUX Z24D
GYRO VALID9a
ADF COS35B
ADF REF18D
ADF SIN17A
MKR IM15C
MKR MM344
MKR OM165
BS SPARE X28
BS SPARE Y9
BS X25
BS Y6
BS ZGRND
26 VAC HI4
26 VAC LO
AP CRSDAT722
AP REF(LO)4
AP HDGDAT2621
AP +10V19
AP -10V20
SER1 IN HI345
SER1 GND163
SER2 IN HI32SLEEVE
SER2 GND14GROUND
SER2 OT HI30TIP
