Ph.D. Meteorologist Documents Impact Of Global Warming On Turbulence
  • Professor Paul Williams warned that 2023's strong El Niño could significantly increase clear air turbulence (CAT) for aviation.
  • Strong El Niño events correlate with a 50% increase in moderate-or-greater CAT over large parts of the U.S. and North Atlantic, with La Niña having the opposite effect.
  • Beyond El Niño cycles, Williams's research also indicates that global warming is a demonstrable contributor to increased air turbulence worldwide.
At a meeting of the American Meteorological Society earlier this year, a U.K. professor warned that 2023’s historically strong El Niño could powerfully affect aviation with increased clear air turbulence (CAT). Paul Williams is an Oxford-educated Ph.D.-level meteorologist who currently heads up a group of 30 atmospheric scientists at the University of Reading in the U.K. According to his bio, Williams’s work focuses on “atmospheric turbulence, jet streams, fluid dynamics, numerical modeling, and climate change, with a focus on weather-sensitive applications, including aviation.” He writes that he is particularly interested in how climate change affects aviation, “including the prospect of more turbulence.”
Compared with La Niña years that have the opposite effect, El Niño increases the incidence of wind shear—conflicting airflows that create severe turbulence not associated with visible storms caused by convective activity. Williams found “when there’s a strong El Niño event, there is 50 percent more moderate-or-greater CAT over large parts of the U.S. and the North Atlantic. And when there’s a strong La Niña event, there’s about 50 percent less moderate-or-greater CAT than normal.” Williams did note that the climate-based effects are not as strong in Europe.
But Williams’s research doesn’t stop with the predictable effects of warmer El Niño years or cooler La Niña interludes. In research conducted in 2019, he concluded that global warming across the board has demonstrably contributed to increased air turbulence, worldwide.
Mark Phelps
