AVmail: November 19, 2012
  • A perceived pilot shortage is anticipated due to the age 65 deadline and 1,500-hour rule, leading to suggestions for lifting age restrictions and re-evaluating pilot experience requirements.
  • Diverse opinions on General Aviation (GA) safety range from arguments against imposing airline-level regulations on private pilots to recommendations for enhanced training in human factors and risk management.
  • Concerns regarding owner-performed maintenance include instances of professional mechanic errors and regulatory ambiguities surrounding what specific tasks are considered preventive maintenance.
Each week, we run a sampling of the letters received to our editorial inbox here in AVmail. One letter that’s particularly relevant, informative, or otherwise compelling will headline this section as our “Letter of the Week,” and we’ll send the author an official AVweb baseball cap as a “thank you” for interacting with us (and the rest of our readership). Send us your comments and questions using this form. Please include your mailing address in your e-mail (just in case your letter is our “Letter of the Week”); by the same token, please let us know if your message is not intended for publication.
Letter of the Week: Pilot Shortage Is Real
Regardless of Sully’s opinion, I have felt for over a year that the approaching age 65 deadline and the 1,500-hour requirement were going to create the perfect storm for pilot recruitment.
The cost to get to 1,500 hours for a new hire is far beyond the reach of the average wannabe. It would seem that now that the FAA has seen five years of data on those older than 60 flying that the fastest cure would be to lift the age restriction entirely and let physical condition serve as the limiting factor.
Another cure is to evaluate new hires by the type of flying that they can prove, not by a number based on towing banners up and down the beach in day VFR in SEL equipment. The Eagle guy is correct. If the regulations are not modified, there will undoubtedly be loss of service to marginal markets.
Fred Yarbrough
GA Safety
The NTSB won’t be satisfied until all GA aircraft are turbine-powered, multi-engined, and piloted by professional pilots on IFR flight plans with gross weights approximately equivalent to a railroad locomotive.
Comparing GA to the airlines is like comparing cars to buses. Furthermore, the GA fatality rate is almost identical to that of motorcycles, and nothing is done about that. Helmets are not required in most states.
Larry Kinder
I think one of the overlooked culprits of accidents in GA is cost. Because of fuel and other costs, we fly less. Flying less means we’re less current. I love to fly, but until I find an economical way to stay current I stay out of the cockpit.
J. D. Watson
The only way that GA can be as safe as the airlines is if we are subjected to the same restrictive regulations as the airlines are. The airlines need to follow those regulations because they are selling their services to the general public, and the services they sell need to be safe.
GA pilots are not selling their services, and they should not be regulated as the airlines. This does not mean that GA pilots don’t need to try to be as safe, but they don’t need to have the government looking over their shoulders all the time. They should keep themselves safe voluntarily.
Recommendations and some changes in training may be O.K., but airline-type regulations should not be forced onto GA.
Margaret Drescher
Training and technology will help, but GA needs the same systematic approach that airlines, business aviation, and the military use.
Pilots need to be trained in human factors and risk management. Leadership skills are key to being a safe, competent pilot in command.
Another important component is extensive use of team resources like ATC, FSS, and the FAASTeam. Learn from others and avoid costly mistakes. Fly smart!
Kent Lewis
GA probably cannot be as safe as the airlines as we do not operate according to the [same] strict rules and procedures. Like the airlines, GA is susceptible to human failure, but unlike the airlines we depend on one human to mitigate those failures.
The result is you can control your own safety but you cannot control the other guy. Humans will continue to err. Unlike other endeavors, GA is unforgiving of brain fade.
Ralph Hoover
You’ve done a great job with this survey, of capturing compatible and equal truths. Yes, the human cost is terrible; yes, we need to do more; no, we won’t get to where the airlines are; and yes, there is super technology that might come close, but it’s currently not financially viable.
Jonathan Micocci
Owner Maintenance
The author of the owner-performed maintenance article writes: “I’ve always been fond of pointing out one of the most dangerous things in personal aviation is a private pilot with a #2 Phillips screwdriver.”
Maybe so, but in the 15 years I owned a 182, I never had an A&P work on it without messing up something in the process, something I later had to fix – and some of them were very good mechanics.
Want to compile a list of “professional mechanic” screw-ups?
Jon Woellhaf
Just read your article about owner-performed maintenance. Years ago, I had a customer with a beautifully maintained Cessna 172. He would perform as much of the maintenance on the airplane as his private pilot certificate would allow. When he accomplished his first owner-performed oil change, I got a call asking me to sign off his cowling installation under my A&P certificate. Quite confused, I asked him why he needed me since this was considered preventive maintenance under FAR 43, Appendix A.
As it turns out, he is correct. The 172 air filter is part of the lower cowling removal and is not specifically called out as preventive maintenance in Appendix A. I’m sure it is one of the many oversights in the FARs but one that private pilots should be aware is an issue.
I recommend a pilot – or, better yet, a pilot group – petition the FAA under FAR 11 to review this issue to see if this could be added as preventive maintenance.
Ray Benischeck
A Matter Of Scale
A one-twelfth-scale Spitfire with a wingspan of 12 feet would be a very odd bird, considering that the Spitfire had a wingspan of just under 37 feet.
Dan Gill
AVweb Replies:
Thanks to everyone who caught the math error.
Editor-in-Chief
